Skunk2 Throttle Body Idle Screw not responding...any ideas?
Old Mar 16, 2006 | 10:56 AM
sirshan's Avatar
Default Skunk2 Throttle Body Idle Screw not responding...any ideas?
Ever since I had my Skunk2 TB put in, it seems like the idle screw is not working. Any ideas what could cause this to fail?
All the way in or out, my idle is the same...
Help!
Old Mar 16, 2006 | 12:02 PM
Spracer03's Avatar
same happened with my 68mm... i just said screw it (no pun intended) and didnt mess with it anymore... does yours idle high?? and get stuck idling around 1.5k when you come to a stoplight???
Old Mar 16, 2006 | 12:07 PM
sirshan's Avatar
Well, I slapped some Stage II Cams, did a new build and idling a bit crazy (high)...when it gets warm...it drops a bit and cant hold the idle.
I just need it to idle decent. My rigged way of doing it was to adjust the throttle cable...now it gets either stuck revving to high...or if i pull the pedal up, it just dies out.
Im putting on my stock GSR one for now until I find out whats going on.
Old Mar 16, 2006 | 12:18 PM
Spracer03's Avatar
i was pissed too when i first put mine on, did you use the skunk2 gasket??? if you did i say ditch it and make your own or modify it!! mine didnt cover one of the passages all the way.. hence the idling high... check it out you might be surprised
Old Mar 16, 2006 | 01:32 PM
sirshan's Avatar
I failed to check fitment...just assumed I guess that it would be ok.
Ill definately check that. Thanks...
Any others with similar experiences?
norwood399
Mar 25, 2019 05:24 PM
Kylehugo
10
Jun 4, 2012 05:27 PM
manicmechanic
Aug 14, 2011 02:30 PM
snowblind7x
Jul 12, 2006 06:52 AM
WhoDoYouThink
Mar 28, 2006 04:02 PM
