Ignition output signal problem of EF *WIRING**
Old Mar 16, 2006 | 09:31 AM
Freeltec's Avatar
Default Ignition output signal problem of EF *WIRING**
ok im getting code 15 after an engine swap. Car is an 89 SI. i have put in a brand new dizzy and the car still wont start. i have checked all my grounds, connections etc. So now i believe that there is a wire in the harness somewhere that is broken. I plan on running a fresh wire from the ecu to the dizzy but i dont know which wires to run. So what i am asking is:
Run X wire from ECU to Y wire on Dizzy.
so what wires am i running? can someone tell me by colour and plug designation. thanks alot, im getting so pissed this BS has had my car down for weeks.
thanks for any wiring help.
Old Mar 16, 2006 | 11:41 AM
Freeltec's Avatar
common guys my nuts are hanging here
Old Mar 16, 2006 | 12:17 PM
pro1342's Avatar
the problem is the computer, not the wiring.....replace it
Old Mar 16, 2006 | 12:56 PM
Freeltec's Avatar
The problem is the wiring, i have tried 3 diffrent ecus that all work. i get the same code for each. thanks but no cigar.
Old Mar 21, 2006 | 03:01 PM
Freeltec's Avatar
bump for more info plz
SoFreshh
Dec 7, 2009 10:08 PM
b18swapef
Apr 6, 2009 08:12 PM
egdriver94
May 5, 2008 10:26 AM
salman
10
Jul 6, 2006 05:41 PM
