Swaped auto for 5 spd, where is the Park sensor? Won´t start.
Old Mar 16, 2006 | 09:08 AM
jwaked's Avatar
Default Swaped auto for 5 spd, where is the Park sensor? Won´t start.
Hello guys, I search but did not find it. I took out the auto tranny on my 96 LS and installed a 5 speed but the car won´t start because it thinks that the tranny is not in the Park position. Help please. Where is the sensor or what can I do?
Thanks
Jay
Old Mar 16, 2006 | 09:11 AM
yellowrexsi's Avatar
Default Re: Swaped auto for 5 spd, where is the Park sensor? Won´t start. (jwaked)
Just to verify, what ecu do you have, I would imagine auto.
Old Mar 16, 2006 | 10:18 AM
jwaked's Avatar
Default Re: Swaped auto for 5 spd, where is the Park sensor? Won´t start. (yellowrexsi)
Since I did the LSVTEC also, I installed a 94 GSR 5 speed ECU with the OBD2-OBD1 harness. The car starts right up if I do it direct with a cable or screwdriver but won´t do anything if I try with the key.
Jay
Old Mar 16, 2006 | 11:53 AM
Jon at Titan's Avatar
Did you do the Wiring where the Auto Shifter Used to be, The 2 big Fat Wires Forget which color. But you just Splice those 2 Together and i will Trick the Car into its being in Park
http://img.photobucket.com/alb...y.jpg
I Connected those together when i did my auto to manual Swap
Old Mar 16, 2006 | 03:49 PM
jwaked's Avatar
You are D man bro, did it and worked perfect. Thanks
qcty_jdmes1
Honda Civic (2001 - 2005)
Oct 15, 2009 02:41 PM
DBG0823
10
Feb 6, 2009 09:03 AM
CNSK
Oct 7, 2007 08:37 AM
jwaked
Mar 16, 2006 03:50 PM
