Axel Chart For EF Civics X Trans + Y knuckle = Z Axel
Old Mar 16, 2006 | 08:39 AM
towboy's Avatar
Default Axel Chart For EF Civics X Trans + Y knuckle = Z Axel
Im posting this over at thzcr.com also
Preface I have a zc trans and ex Knuckles And was tryin to figure out
what axel to use I figured that out but not sure what Knuckles i'm currently using
after thinking about this is it possible that both my 90 si hatchbacks came with STD knuckles I doubt that. Are'nt the tha DA knuckles more similar to the EX. If so the EX knuckles would use the the DA. What would you use for the SI and DX. Everybody says use the 90-93 but I know the 2 are different. Maybe we could make a flow chart for trans, axel, knuckle, combos
Axel Tech For 88-91 Civics
STD Hub accepts axels with 23 splines
SI, DX, LX, EX and DA hubs accepts axels with 26 splines
SI, DX, LX, EX, DA, and STD Transmissions accepts axels with ??
SI, DX, LX, EX, DA, and STD Seals have 35mm axle seal diameters
ZC and B series Transmissions accepts axels with 27 splines
ZC R/S Seal part # 91205-PC9-711 (40 X 62 X 8) L/S # 91205-PL3-B01 (40 X 56 X 8)
SI, DX, LX, STD, trans + STD knuckles = Stock axel for STD
SI, DX, LX, STD, trans + SI knuckles = Stock axel For SI
SI, DX, LX, STD, trans + EX knuckles = Same as SI
SI, DX, LX, STD, trans + DA knuckles = Stock axel for SI
ZC or B series trans + STD knuckle = Rightside: Rgt DA axel with STD Outboard Joint /Leftside: Rgt DA inboard joint With Lft STD Outboard joint
ZC or B series trans + SI knuckle = Rightside: Rgt DA axel /Leftside: Rgt DA inboard joint With Lft SI axel
ZC or B series trans + EX knuckle = Rightside: Rgt DA axel /Leftside: Rgt DA inboard joint With Lft SI axel
ZC or B series trans + DA knuckle = Rightside: Rgt DA axel /Leftside: Rgt DA inboard joint With Lft SI axel
ZC or B series trans + Intermediate shaft + STD knuckle = Rightside: Rgt DA axel with STD Outboard Joint /Leftside: Lft DA axel With STD Outboard joint
ZC or B series trans + Intermediate shaft + SI knuckle = DA axel
ZC or B series trans + Intermediate shaft + EX knuckle = DA axel
ZC or B series trans + Intermediate shaft + DA knuckle = DA axel
NOTE : ZC and B series Intermediate shafts are Different in design but splines are the same Correct me if I'm wrong
This option will not work AWD intermediate shaft is to small for tranny
ZC trans + AWD Intermediate shaft + STD knuckle =
ZC trans + AWD Intermediate shaft + SI knuckle =
ZC trans + AWD Intermediate shaft + EX knuckle =
ZC trans + AWD Intermediate shaft + DA knuckle =
ZC Hybrid Intermediate shaft:
88 Integra shaft + AWD Mount = ZC Intermediate shaft
Maybe also the seal numbers for the corresponding Setup would be good
DA axel install tip
http://www.thezcr.com/forums/showthread.php?t=8751
Sorry about this but it is the only info I cant find doing a search or reading countless posts EDIT: Maybe both my SI's had STD Knuckles
Modified by towboy at 2:27 PM 3/16/2006
Modified by towboy at 6:34 AM 3/21/2006
Modified by towboy at 6:35 AM 3/21/2006
Modified by towboy at 7:49 AM 3/21/2006
Old Mar 16, 2006 | 08:48 AM
towboy's Avatar
Default Re: Axel Chart For EF Civics X Trans + Y knuckle = Z Axel (towboy)
I have found two part Numbers from honda for the EX Hub
Old Mar 16, 2006 | 11:48 AM
towboy's Avatar
The axels I'm currently using fit an SI trans but will not fit the EX Knuckles
Old Mar 17, 2006 | 04:47 AM
towboy's Avatar
nobody can help add to this I'm tryin to get another resource together here sombodys got to seal part numbers or anything to help this thread
Old Mar 21, 2006 | 05:34 AM
towboy's Avatar
EDIT and still looking for some more info plz add i f you have any
nightscream
17
Aug 2, 2011 06:33 PM
keeblar
Jul 20, 2008 04:05 PM
headhunter
10
Jun 26, 2006 03:42 PM
acuratech
Jan 24, 2005 01:37 PM
JonGP4
Jul 22, 2003 10:10 PM
