ABS brake set-up to non ABS
Old Mar 16, 2006 | 05:14 AM
Civic138's Avatar
Default ABS brake set-up to non ABS
could i use whole brake set-up even though there ABS, even if i changed the calipers to non-ABS calipers?
Old Mar 16, 2006 | 05:32 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Default Re: ABS brake set-up to non ABS (Civic138)
Do you want the ABS to work still, or not work, after putting on non-abs calipers?
Old Mar 16, 2006 | 06:27 AM
Civic138's Avatar
Default Re: ABS brake set-up to non ABS (phoenix_iii)
no i dont want ABS
Old Mar 16, 2006 | 02:18 PM
mahatma's Avatar
Yes you can use them. I'm pretty sure you can even use the calipers, but the prop valve is different.
Old Mar 16, 2006 | 03:19 PM
Civic138's Avatar
Default Re: ABS brake set-up to non ABS (mahatma)
i know the prop. valve isn't the same, but i was taking about how the whole wire system will make anything different
LM1092
Jul 3, 2012 04:24 PM
c|rop3asy==[]
Jun 14, 2011 06:22 PM
get RIGHT
Suspension & Brakes
Jun 23, 2009 11:59 PM
Cyber ITR
Dec 27, 2007 09:03 AM
