AZENIS RT-615 tires
Old Mar 15, 2006 | 10:46 PM
marc-111's Avatar
Default AZENIS RT-615 tires
i have a 2000 coupe civic lowered in tein s-techs stock struts
i have a 16 X 7 inch rims +42 offset
which tire size would i use?
AZENIS RT-615 only got 205/40R16, 215/45R16 and 225/50R16?
Old Mar 15, 2006 | 11:18 PM
OMG WTF's Avatar
Default Re: AZENIS RT-615 tires (marc-111)
205
Old Mar 15, 2006 | 11:34 PM
old man neri's Avatar
Default Re: AZENIS RT-615 tires (zclee.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zclee.com &raquo;</TD></TR><TR><TD CLASS="quote">205</TD></TR></TABLE>
bingo. That is the closest to your stock diameter and width.
However, just double check in the Falken Azenis 615 spec sheet if 7" is within the 'approved wheel width'. Most 205/40-16s have an approved width of 7-8" but I am not to sure about the Falken, just double check.
Cheers.
Please tell me that living in "QC" you do not plan to use these tires in the snow.
Old Mar 16, 2006 | 06:40 AM
marc-111's Avatar
thanks!!!
nope i'll only use it for shows
just found out that 205,40 r16 measuring with is 7.5". Is it still good for a 7"?
Old Mar 16, 2006 | 02:55 PM
alwaysoverkill's Avatar
I'm in the same situation. 205/45/16 would be closer to my stock size of 195/55/15 however RT-615 does not come in that size yet, so i'm rocking 205/40/16 on 16x7" Buddy Club SF which aer going on the car when weather is above 10c here, so 2-3 weeks.
205/40/16 is smaller at 22.5" overall, and will throw off the speedo/odometre 4.XX % but so long as your aware of the speedo being off and the fact it will give slighlty taller gearing, your call.
Old Mar 17, 2006 | 12:38 PM
nsxtasy's Avatar
H-T Order of Merit
The stock size for your car is 195/55-15, right? Then get 215/45-16, which is only about 0.8 percent larger in outer diameter than stock.
205/40-16 is WAY too small for a car that takes 195/55-15 stock.
Old Mar 17, 2006 | 12:54 PM
Default Re: AZENIS RT-615 tires (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">The stock size for your car is 195/55-15, right? Then get 215/45-16, which is only about 0.8 percent larger in outer diameter than stock.
Wow, I don't know what the ** I was thinking. Oops, sorry.
Old Mar 17, 2006 | 10:17 PM
marc-111's Avatar
mine is an EX coupe when i bought the car it got a 195/65 r14
Old Mar 18, 2006 | 06:13 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marc-111 &raquo;</TD></TR><TR><TD CLASS="quote">mine is an EX coupe when i bought the car it got a 195/65 r14 </TD></TR></TABLE>
The stock size for the 2000 EX Coupe is 185/65-14, which has exactly the same outer diameter as 195/55-15 (which is the stock size for the 2000 Si Coupe). Sounds like the previous owner put oversized tires on your car.
The best matching 16" sizes for your car are 205/45-16 and 215/45-16. Of those two sizes, the Azenis RT-615 is available only in 215/45-16, so that's what you should get.
Old Mar 18, 2006 | 06:41 AM
Chris_'s Avatar
if the tire fits get the widest size you can.
Old Mar 18, 2006 | 06:58 AM
marc-111's Avatar
oh ic so that explains the high mileage but clean body! hehehe! but the 215/45 wont rub on my inner body if i make a full turn?
Old Mar 18, 2006 | 09:48 AM
Default Re: AZENIS RT-615 tires (Chris_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris_ &raquo;</TD></TR><TR><TD CLASS="quote">if the tire fits get the widest size you can.</TD></TR></TABLE>
Why?
Old Mar 18, 2006 | 01:54 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (marc-111)
Bad advice. Using oversized tires can result in rubbing, slower acceleration, and inaccuracy of the speedometer and odometer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marc-111 &raquo;</TD></TR><TR><TD CLASS="quote">the 215/45 wont rub on my inner body if i make a full turn?</TD></TR></TABLE>
You'll have to try it to be sure, but I'm guessing probably not. The '94-01 Integras have 185/65-14 or 195/55-15 stock tires (depending on model) and 215/45-16 fits without rubbing.
Old Mar 18, 2006 | 10:53 PM
marc-111's Avatar
Default Re: (nsxtasy)
im getting the 215/45 r16
i did some research and it is really close to stock size of my 185/65 r14 or the si ones 195/55 r 15
thanks guys!
Old Mar 19, 2006 | 12:56 AM
Doopreme's Avatar
Im facing the same problem on what size to get for my integra, i will Be pruchasing a set of falken Azenis Rt615 but have no idea what size on tire to get. The rims i will be putting them on are some slips 16x7 i want to go 215-45-16 but the rubbing problem comes into play and the 205-40-16 seens to be to slim if anyone could post pictures this would be a big help thx! input would be nice 2
Old Mar 19, 2006 | 05:21 AM
marc-111's Avatar
Default Re: (Doopreme)
as ling as you dont drop your car that much or drop it just too close to the fenders your good coz 205/40 is too small for the rims
Old Mar 19, 2006 | 09:03 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doopreme &raquo;</TD></TR><TR><TD CLASS="quote">Im facing the same problem on what size to get for my integra, i will Be pruchasing a set of falken Azenis Rt615 but have no idea what size on tire to get. The rims i will be putting them on are some slips 16x7 i want to go 215-45-16 but the rubbing problem comes into play and the 205-40-16 seens to be to slim if anyone could post pictures this would be a big help thx! input would be nice 2</TD></TR></TABLE>
215/45-16 won't rub on your Integra (assuming you get wheels with the proper offset). Lots of Integra folks got the 215/45 RT-215 and are getting the 215/45 RT-615 now that it's available.
Old Mar 30, 2006 | 06:41 AM
EKhothatch's Avatar
Does anyone know when the 215/45ZR16 RT-615 are coming out?
Old Mar 30, 2006 | 07:25 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (EKhothatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhothatch &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know when the 215/45ZR16 RT-615 are coming out?</TD></TR></TABLE>
They are already available now.
Vulcan has them on their website. Other places may not have updated their websites yet, but they should be able to get them.
D-Rob
Mar 29, 2006 03:24 PM
99blackLS
Feb 18, 2006 08:50 AM
v0lcom27
13
Aug 29, 2005 12:01 PM
Pondus
Oct 4, 2003 03:23 PM
irdprelude
Nov 16, 2002 02:43 PM
