95 civic problem.
recently, my cars been acting up. its slowly been dying down. it'll crank and crank but it seems as if its getting no spark. within the past 2 weeks its gradually gotten worse and worse to the point where it doesnt want to start anymore. its fuel injected, but say i crank it to the point where it sputters, i can give it gas and it'll fire up. but a few blocks down the road itll want to stall. if the motors kind-of warm, itll start up a little easier, but if i let it sit over night, its a bitch to get running, so i've been using another car. if theres anyone that would know any thing about this situation, the help is appreciated.
thanks.
-steve
note: i recently installed a viper 791xv alarm w/ remote start, i dont believe it being installed is the problem, but the feature may have hurt he car?
thanks.
-steve
i'd say distributor but check your main relay first. its easy and cheaper then doing distributor
http://www.marklamond.co.uk/ho...y.htm
21 one gun salut take out your fuel rail hold the injectors in the rail and have some one crank the car (dont stand in front of the injector spray) you wil be abel to see if the spray the same or one will be less then a nother if not this you will have to have them tested
stdefhatch
May 6, 2006 01:54 AM
2000Accord5sp
Aug 22, 2004 08:06 AM
