*Used Goodies from Ebay*.... now how do i install thiz?
Old Mar 15, 2006 | 09:18 PM
PhantomX's Avatar
Default *Used Goodies from Ebay*.... now how do i install thiz?
Hey, i just got this great deal for a Integra gauge bezel with two autometer gauges (boost and Air/fuel gauges) all for only $50 bux....
any tips on how to install this properly?, i know how to install the boost gauge but its the air/fuel gauge im concerned about...I did a search but only found articlez on how to install gauge clusters...
THankx In ADvANCe!
Old Mar 15, 2006 | 09:36 PM
LoseRPunKx182's Avatar
Default Re: *Used Goodies from Ebay*.... now how do i install thiz? (PhantomX)
power, ground and o2 wire on ecu...nothin to it
Old Mar 15, 2006 | 10:17 PM
rdblckSV650S's Avatar
Default Re: *Used Goodies from Ebay*.... now how do i install thiz? (LoseRPunKx182)
^^ yup
but you might as well not hook it up, it's just a light show, and won't telll you anything useful.
Old Mar 15, 2006 | 10:19 PM
Dc_John's Avatar
nice pick up 50 bux aint bad.
Old Mar 15, 2006 | 10:25 PM
four1one
Guest
Posts: n/a
Default Re: *Used Goodies from Ebay*.... now how do i install thiz? (slvrblckf4i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slvrblckf4i &raquo;</TD></TR><TR><TD CLASS="quote">^^ yup
but you might as well not hook it up, it's just a light show, and won't telll you anything useful.</TD></TR></TABLE>
So if your boostin 15 pounds at 6500 RPM and suddenly your guage goes red its just gonna be a light show? Nothing to worry about right?
Old Mar 15, 2006 | 10:48 PM
string's Avatar
Default Re: *Used Goodies from Ebay*.... now how do i install thiz? (four1one)
If he is boosting 15pounds at 6500rpm and he goes to 13.5:1 a:f for some reason its not going to show ****.
If you are so lean on that much boost that you go red on a narrowband, then say goodbye.
Old Mar 15, 2006 | 10:55 PM
PhantomX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoseRPunKx182 &raquo;</TD></TR><TR><TD CLASS="quote">power, ground and o2 wire on ecu...nothin to it</TD></TR></TABLE>
what color is the o2 wire in the ecu? I also heard people wireing it to the o2 sensor on the headerz same **** right?
Old Mar 16, 2006 | 05:07 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
"thiz"? "headerz"?
Chunk that A/F guage and get an exhaust gas temp. guage. That will tell you more about your air/fuel ratio than that A/F toy will.
If you're boosting, I think exhaust gas temp. would be pretty important anyway.
Old Mar 16, 2006 | 05:30 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by four1one &raquo;</TD></TR><TR><TD CLASS="quote">So if your boostin 15 pounds at 6500 RPM and suddenly your guage goes red its just gonna be a light show? Nothing to worry about right?</TD></TR></TABLE>
if ur boosting at 15psi and something goes wrong u'll know. narrowband has inaccurate readings
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhantomX &raquo;</TD></TR><TR><TD CLASS="quote">what color is the o2 wire in the ecu? I also heard people wireing it to the o2 sensor on the headerz same **** right?</TD></TR></TABLE>
mine was white on the harness. why wire it up there when ur ecu is in-cabin and closer
Old Mar 16, 2006 | 05:35 AM
InLimbo87's Avatar
the a/f gauge is useless, but I would hardly think of a boost gauge as "useless"
Old Mar 16, 2006 | 12:48 PM
PhantomX's Avatar
Default Re: *Used Goodies from Ebay*.... now how do i install thiz? (InLimbo87)
imma look into buyin a exhaust gas temp gauge..... thankz for the info fellas
Old Mar 16, 2006 | 01:58 PM
four1one
Guest
Posts: n/a
So your telling me honda made a sensor just so it can throw out inaccurate reading? If it goes lean in those circumstances he can shut the car off and have a chance to save the motor....
Old Mar 16, 2006 | 02:38 PM
Community Builder
the OEM narrowband sensor is enough to trigger a CEL, but the voltage/resistance range of variance is not really enough to give an accurate reading on those A/F guages. You really need a wideband sensor to make the guages worth anything.
Old Mar 16, 2006 | 03:02 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: *Used Goodies from Ebay*.... now how do i install thiz? (PatrickGSR94)
i dont think he was refering to the boost gauge when he said useless, but that A/F thing is completely useless
Old Mar 16, 2006 | 05:21 PM
RexShop's Avatar
four1 don't be ignorant.. the air/fuel gauge IS a light show...
Get a wideband if you want to see your air/fuel.
Old Mar 16, 2006 | 08:13 PM
darrinbrewer's Avatar
Default Re: (RexShop)
i'll have to agree about the light show, if on a stock ecu, it just goes back and forth constantly, if on crome with 02 disabled, it can give an idea,
either fuel, or in the red no fuel
best bet is a AEM UEGO guage with wideband, EASILY found on ebay for $250 shipped (killer deal)
i have a wideband display and a oil pressure guage (electronic with sending unit under hood)
all motor car
Old Mar 16, 2006 | 10:31 PM
Deluzional's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RexShop &raquo;</TD></TR><TR><TD CLASS="quote">
Get a wideband if you want to see your air/fuel.</TD></TR></TABLE>
ali7up
Feb 17, 2006 12:18 AM
tzenisj
16
Mar 3, 2004 04:25 PM
shift6th
Feb 10, 2004 04:52 PM
stingray2772
21
Jan 14, 2003 04:01 PM
