I need clutch help BAD!!!!!
Old Mar 15, 2006 | 05:57 PM
I Like Hondas's Avatar
Default I need clutch help BAD!!!!!
So I was driving tonight and out of nowhere my clutch just loosens up! Its like I press it in all the way and at the VERY end it kinda catches.??? Anyone know whats wrong and how to fix it? - Thanks
Old Mar 15, 2006 | 05:59 PM
veilsides2000's Avatar
Default Re: I need clutch help BAD!!!!! (I Like Hondas)
try bleeding it again. or maybe your pressure plate took a **** on you.
Old Mar 15, 2006 | 06:00 PM
fliptout2's Avatar
It sounds like it may be the nut on your clutch cable. Or the cable may have slipped out of its guide.
Old Mar 15, 2006 | 06:02 PM
Default Re: I need clutch help BAD!!!!! (fliptout2)
How do you handle it? or is there anyway to check?
Old Mar 15, 2006 | 06:19 PM
fliptout2's Avatar
Have a friend step on the clutch while you watch the front of the tranny. Check to make sure that there is pressure on the cable. If the cable is still on its guide and the nut is still there then its probably internal.
Old Mar 16, 2006 | 04:36 AM
M Coop's Avatar
What car are you talking about? Does it have a cable or hydro clutch?
Old Mar 16, 2006 | 04:54 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Like Hondas &raquo;</TD></TR><TR><TD CLASS="quote">So I was driving tonight and out of nowhere my clutch just loosens up! Its like I press it in all the way and at the VERY end it kinda catches.??? Anyone know whats wrong and how to fix it? - Thanks</TD></TR></TABLE>
clutch fluid is low, happened to me just last week because my clutch master cylinder is leaking.
Old Mar 16, 2006 | 02:06 PM
Clutch fluid huh? Where do I fill it? And how do you tell if the master cilinder is leaking?
Old Mar 16, 2006 | 02:40 PM
Community Builder
Default Re: (I Like Hondas)
mine leaks down inside the cabin where the clutch pedal connects to the master cylinder push-rod.
Open the hood and find the small reservoir right next to the larger brake master cylinder reservoir and see if there is any fluid inside.
Wazup
Oct 6, 2008 08:37 PM
baboracus
Sep 4, 2007 08:09 PM
1SIKEF8B20VTEC
Oct 5, 2005 04:44 PM
InJ3cted
May 24, 2005 02:16 PM
asmallsol
Aug 9, 2004 08:06 AM
