need help with a motor swap in my 94 DC2
Old Mar 15, 2006 | 05:35 PM
NosCivic01's Avatar
Default need help with a motor swap in my 94 DC2
please help
ive searched the older topics but couldnt find nething.
i have a 94 integra GSR with a 95 motor in it (GSR) and it is turbo. i bought a new motor built for turbo but my problem is its a 98 GSR BLOCK with a 2000 B16 Head. i have a OBD1 ECU p72 that i want to use for my turbo setup since its already chipped out.
now my question is for me to put this motor in wat will i need to do and buy to install the new motor. i kno i can use my old tranny wit started and my old alternator. but what esle do i need. is there a harness i could just buy? please help me.
Old Mar 16, 2006 | 09:00 AM
NosCivic01's Avatar
Default Re: need help with a motor swap in my 94 DC2 (NosCivic01)
nobody can help me???
Old Mar 16, 2006 | 09:16 AM
DC2SIR-G's Avatar
* B A N N E D *
just install it like how all gsr motor should be installed
Old Mar 16, 2006 | 09:19 AM
dohcMONSTER's Avatar
just swap out the long blocks and use the ODB1 injectors since your harness is pinned for them already. your harness will work you just need to take your time and you should be fine since you are running an OBD1 ecu already
Old Mar 17, 2006 | 09:19 AM
NosCivic01's Avatar
Default Re: need help with a motor swap in my 94 DC2 (dohcMONSTER)
alrite great. the b16 head with the inake has no sensors on it either...am i able to use my gsr sensors in this manifold? im not going to b using the map because i already have a GM 3 Bar Map sensor. also the GSR distributor will or will not fit in the b16 head? please let me know
Old Mar 17, 2006 | 09:35 AM
CleanLikeJdm's Avatar
Hype-R Stalker
You need the odb1 injectors, dizzy, and alternator.
Thats what I remember from my odb2 engine swap.
The evap setup might be a little funny,
I have one not plugged in for it, but it runs fine with no codes.
Old Mar 17, 2006 | 10:55 AM
NosCivic01's Avatar
Default Re: need help with a motor swap in my 94 DC2 (FlatBlackTeg)
thanks so im gona b using my old dizzy, alternator, and injectors. ill figure out the rest i think
reaper562
10
Jul 4, 2011 10:15 PM
zipperchamp
Dec 25, 2007 07:12 AM
kajay1972
11
Sep 2, 2007 03:32 PM
koldkustoms
Mar 12, 2007 01:08 PM
NsX_CrX
Nov 18, 2005 03:12 AM
