Kosei K1s in 15x7"...any rubbing?
Old Apr 1, 2002 | 03:23 PM
DevinW's Avatar
Default Kosei K1s in 15x7"...any rubbing?
Hey,
Do any of you guys know if the Kosei K1 Racing rims in 15x7" on a 195/15/55 or 205/15/50 tire will rub on an eg with say, a 2 inch drop? I tried a search but it seems to be broken lately...
Old Apr 1, 2002 | 03:39 PM
SpiceyRice's Avatar
Default Re: Kosei K1s in 15x7"...any rubbing? (DevinW)
I run 205/50s on my K1 (15x7 38off) EG without any rubbing. ...but that's with sensible lowering (about 1-2 finger gap), I'm not sure if it'll rub with a 4" drop.
Old Apr 1, 2002 | 04:41 PM
EkREV's Avatar
New User
Default Re: Kosei K1s in 15x7"...any rubbing? (SpiceyRice)
go 195/50-15's
Old Apr 1, 2002 | 04:59 PM
DevinW's Avatar
Default Re: Kosei K1s in 15x7"...any rubbing? (EkREV)
Will the 195/15/50s be alright with a 7 inch wide wheel like that?
Old Apr 1, 2002 | 05:10 PM
SpiceyRice's Avatar
That'll be perfect.
Old Apr 1, 2002 | 05:14 PM
jgale's Avatar
My 15x7's with 38 offset k1's with 205/50 15 Hoosier r3s03's(measure more like a 225) only rubbed if I hit the curbs hard at the track. My hatch is plenty low. On street 205/50's you'll be more than fine. 195/50 15's look anemic.
Old Apr 1, 2002 | 06:28 PM
xdevo tekkianx's Avatar
Default Re: Kosei K1s in 15x7"...any rubbing? (jgale)
yah you should'nt get much rubbing, if any at all, with 195/50.
Old Apr 2, 2002 | 05:52 AM
CivicSiRacer's Avatar
Default Re: Kosei K1s in 15x7"...any rubbing? (xdevo tekkianx)
I have the 15x7" Kosei K1 in 45mm offset and the inner lip of the wheel hit the rear upper control arm which I fixed by filing it down and buying a 3mm spacer. I have 205/50x15" Azenis tires.
Old Apr 2, 2002 | 06:34 AM
DragII's Avatar
25 Year Member
Default Re: Kosei K1s in 15x7"...any rubbing? (CivicSiRacer)
I'd go w/ 205s...I'm running 195s right now...and it's too easy to push them to their limit...pi largo emilio!
JonathanCD5
Sep 6, 2014 08:45 AM
vtec128
Suspension & Brakes
Oct 29, 2009 09:46 PM
HiPhOpHeADs
Sep 14, 2006 10:08 PM
Daniel san
13
Apr 6, 2005 04:19 PM
CeoStatus0
10
Jul 25, 2004 12:27 PM
