Bluish smoke coming out of the engine bayy..
I have a B18C1 swap and been having problems starting my car lately. Today I was trying to crank it up and it refused to do so, so I turned if off.(Moved key from starting position to acc) After I stopped the car did a howling noise and I see bluish smoke coming from the hood. I open the hood quickly and notice the smoke coming out of the intake tube. I have a SRI. What could be the cause of this? I took the filter off and let all the smoke come out and tried to get the car started and it did after a good bit of cranking..
Cliff Notes:Bluish smoke coming out of the intake tube
Thanks!
Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGhatch33 »</TD></TR><TR><TD CLASS="quote">do u have the tube hooked up between your intake and your valve cover?</TD></TR></TABLE>
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">When the cam timing is off it spits smoke out of the intake..Maybe slipped a tooth..?</TD></TR></TABLE>
hmmm, how do i check if this is the problem?
yes
check the timing with a timing light..Or set the motor to tdc and see if the arrows on the cam gears are lining up,maybe just one cam gear is off..
crxtreme27
Jan 12, 2005 02:00 PM
wizzards581
Oct 24, 2003 06:41 AM
