How do you remove the rotor off of the distributor?
I'm a real noob when it comes to doing my own work but i got the dizzy cap off and now i can't tell how to get the rotor off? There is a protective plastic shield over where it looks like i'm supposed to take it off... Can someone help me out please
There should be a little screw on the neck of the rotor holding it in place. If after you take the cap off and you cant see the screw, you need to bump the ignition over so that it turns and the screw is visible on the neck of the rotor. It might be alittle hard to take off because the screw has a lock washer but try not to strip it out!
by bump the ignition do you mean like turning to motor over? I also cannot see the screw. One last thing... like a dumbass i pulled off all of the spark plug wires without marking where each goes... Could someone tell me this for the h23?
expletive I got the dizzy off and i got the screw but i'm stripping the **** out of it just trying to take it off!!! How the hell are you supposed to get that off?
I used some needle nose pliers around the head of the screw to break it loose. If your looking from the passenger side fender the order is 1 3 4 2 starting at the bottom left and rotating in a clock wise rotation.
I don't know what i'm going to do because i'm still haveing a hell of a time getting that damn screw off... I can't find my pliers
If the screwhead is "screwed", try cutting a slot across the top of it and use a flathead screwdriver to get it off. If this is the first taking this out, it's probably stuck in there pretty good. Maybe a squirt of WD40 to loosen it up?
Good luck!
Good luck!
******* thing is impossible to get out. On my 93 I tried everything - vice grips, cutting a slot, etc etc. Finally bought a craftsman screw out kit and it still wasn't working. Bumped the drill up to the top torque setting and and nailed 'er. The bit exploded but it finally broke torque on that ******* screw. I still have the thing too with half a drill bit stuck in it.
Well **** now my car won't start
I said expletive the rotor once i stripped the bolt most of the way so i put it back in, put it back together and replaced plugs @ wires and now it just turns over... Could I have scratched up the rotor or beat it up enough to where it wouldn't start anymore?
you prolly didn't put on the spark plug wires correctly.
i just took off the whole distributor (first mark your timing settings on the bracket holding the distributor)
and then its easier to get to the nut on the rotor because you have leverage if you put the distributor on the ground
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doom325 »</TD></TR><TR><TD CLASS="quote">I have it 1-2-3-4 (left to right) on the valve cover then 1-3-4-2 on the dizzy starting at the bottom left. Is taht not right?
On the cap, there should be an A stamped. That is cyl #1. (BTW, Cyl #1 is the furthest one away, by the timing belt) Counterclockwise from A, #1, is #2, then #4 (which has a stamp C), then #3.
So looking at your motor:
4 3 2 1
The plug wires should go:
2 1
4 3
Hope that helps.
BTW, did you take the entire distributor off? Or just the cap and rotor? Because if you removed the distributor, you might have accidently fully advanced/retarded the ignition timing.
4 3 2 1
2 1
4 3
Hope that helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doom325 »</TD></TR><TR><TD CLASS="quote">Finest... You are a life saver
I'm going to have to wait on the rotor but she's running again!
HaHa! Good to hear!
</TD></TR></TABLE>HaHa! Good to hear!
um i was wonderin if i can get a lil help too..my car died on me while driving, it styll cranks and everything but wont start. ne help would b awsome. its a d16y8 motor.
sry
sry
zairas
Oct 19, 2009 03:08 PM
