jerk on second gear
Old Mar 15, 2006 | 12:43 PM
kihun_cha's Avatar
Default jerk on second gear
when i change gear to second.. and start accelerating.. the bike jerks.. any idea why?? this is suzuki gsxr 600 2001 model
Old Mar 15, 2006 | 12:58 PM
Sijray21's Avatar
Default Re: jerk on second gear (kihun_cha)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kihun_cha &raquo;</TD></TR><TR><TD CLASS="quote">when i change gear to second.. and start accelerating.. the bike jerks.. any idea why?? this is suzuki gsxr 600 2001 model</TD></TR></TABLE>
is it just not a smooth transition (too much or not enough throttle)?
if not, more explaination please
Old Mar 15, 2006 | 01:00 PM
Rednas's Avatar
since its still kinda of a high gear (mathematically)its more easily affected than others if you are not smooth. which might be the reason why you only feel it in second gear and not others even if you use the same technique. Most likely its user error not the bike.
Old Mar 15, 2006 | 03:02 PM
rdblckSV650S's Avatar
Default Re: jerk on second gear (Rednas)
Like rednas said, it's still a high gear and requires a bit of throttle control and a steady hand. Practice makes perfect.
Unless you're saying the bike is bogging, in which case it would be the bike.
What RPM are you shifting at, or does it happen all the time no matter what.
Old Mar 15, 2006 | 06:12 PM
kihun_cha's Avatar
i was going 25 on 2nd gear.... hmm i think i still dont know the bike gear ratio.. gotta learn .. so you guys think its not the bikes fault rigt?
Old Mar 15, 2006 | 07:58 PM
Default Re: (kihun_cha)
I want to know what RPM you're at in what gear.
Beyond that, again, it's probably just throttle control. Unless you're trying to say that it bogs, in which case, it's the bike.
Old Mar 15, 2006 | 08:01 PM
bustdesenuts's Avatar
it might be the oil...i noticed when i switched over to full syn, the bike shifted much smoother.
motul 5100 15w50
Old Mar 19, 2006 | 12:08 PM
kihun_cha's Avatar
ok so i rode my bike one more time today when it was like 40 degrees outside.. and when i was riding it.. i changed to second gear around 35mph than i put accerlation than the bike jersk constanly every 4 seconds or so.. it sounds like poping gear chain or something.. im not too sure about motorcycle but **** is bothering me a lot..
Old Mar 19, 2006 | 01:05 PM
AGAIN, what RPM is this happening at.
Also, have you checked your chain slack?
My MSF bike's chain was so loose the top nearly touched the bottom. It made for an extremely jerky ride, but once i got into 3rd it was a little more tame.
Old Mar 19, 2006 | 04:12 PM
kihun_cha's Avatar
it jerks every 3 or 4 second in second gear no matter what RPM i am on
Old Mar 19, 2006 | 04:37 PM
pearramp's Avatar
if you have never lubed your chain it could be that. also when my clutch went out on my daytona it did that but not as extrme as yours sounds. just thought i would give my 2 cents
Old Mar 19, 2006 | 06:22 PM
Luke's Avatar
If it is a fault the way to test is this...
Start of in first shift early to second at 2K open the thottle wide.
Repeat this but next time don't use the clutch on the change up.
If there is a difference you have your problem.
Old Mar 20, 2006 | 06:00 AM
kihun_cha's Avatar
mabye i have to adjust gear?
nthai
Honda Motorcycles
22
Dec 1, 2011 06:12 PM
playahwitgame
Honda Motorcycles
43
Jul 2, 2007 09:24 PM
BusaWill
Honda Motorcycles
59
Sep 11, 2006 04:42 PM
falcongsr
Honda Motorcycles
15
May 17, 2004 07:06 AM
99lspwr
Honda Motorcycles
Sep 17, 2003 05:11 AM
