Valve Cover Leak?
Old Mar 15, 2006 | 12:32 PM
HondaMike17's Avatar
Default Valve Cover Leak?
now im 95% positive that this is the problem, this accord is basically mint, 97 LX accord 4cyl..
recently ive been noticing a little oil on 3 of the 4 spark plug caps, which means there is oil down below too, i changed my spark plugs today and there wasnt as much oil as i expected but it was a good amount, ive diagnosed this 1 problem and ive come to the conclusion that it must be my valve cover leaking through the gasket, but seeing as theres still that 5% that im unsure of i decided to ask my friends at Honda Tech .. all replies are appreciated, (hoping a gasket is all ill have to fork out money for
Old Mar 15, 2006 | 12:57 PM
P_Adams's Avatar
Default Re: Valve Cover Leak? (HondaMike17)
Here's what you're dealing with
Parts listings: #1 Gasket set
http://www.hondaautomotivepart...COVER
AND: #19 "O" rings (4)
http://www.hondaautomotivepart...81%29
These require pulling the rocket assembly (which forms part of the Spark Plug Well)
If you don't own a shop manual, now is an excellent time to buy one. During reassembly, you MAY have to readjust the valve lash.
P
Old Mar 15, 2006 | 01:15 PM
YeuEmMaiMai's Avatar
how many miles on it?. I'd just do a valve adjustment and replace the gaskets/grommets/tube seals with new ones at that time.
Old Mar 15, 2006 | 03:00 PM
BLKFLSH's Avatar
You can try just changing the seals under the valve cover. But it will probably be the o-rings under the rockerarm assy. The link below has all the information.
http://www.cb7tuner.com/vbb/sh...+tube
PS: there is one thing the link doesn't mention until way too late. You need to back off all the valves before removing the rockerarm assy. Then re-set the valves after changing the o-rings. Have fun.
Old Mar 15, 2006 | 05:32 PM
Default Re: Valve Cover Leak? (BLKFLSH)
its got 125k at the moment, and thanks guys, i have the money and the experience to do this, i was just looking for some other perspectives..
Old Mar 15, 2006 | 06:52 PM
BLKFLSH's Avatar
It's not an expensive job (if you do it yourself) just gaskets and o-rings. But you have to know how to set the valves etc.
Old Mar 16, 2006 | 03:20 AM
cd5_2NR's Avatar
its probably the valve cover gasket + the little O rings that go around the spark plug...had the same problem and fixed it recently...about $20.00 for the gaskets...
JeffyHfx
May 18, 2008 10:39 PM
four.six
Oct 17, 2005 07:30 AM
JaySR20
Mar 29, 2005 01:42 PM
BrokeLude
Aug 19, 2004 11:42 AM
4genaccordfreak
Jan 4, 2004 01:07 PM
