Stubborn Lugnut question....
Old Mar 15, 2006 | 12:26 PM
shredder22's Avatar
Default Stubborn Lugnut question....
I have two lugnuts that just won't loosen with the tool. They are about half way off right now and they are just stuck. I have no idea how to get these off. Any help out there?
Old Mar 15, 2006 | 12:30 PM
schardbody's Avatar
you are gonna have to go back and forth until they snap off. then you are gonna need some new wheel studs.
Old Mar 15, 2006 | 12:31 PM
ZipTieGUy's Avatar
wont loosen... you mean wont spin or keep spinning?
make shure the wheel is pushed in
Old Mar 15, 2006 | 12:32 PM
yellowrexsi's Avatar
Default Re: Stubborn Lugnut question.... (shredder22)
Try to turn then back in slowly and then back out. They should come loose. If you have access to a torch, try to heat them up. Chances are, the struds or lugnuts are stripped.
Old Mar 15, 2006 | 12:49 PM
shredder22's Avatar
Im pretty sure the lugnuts are stripped, luckily Im putting new ones on, but I will try turning it back and forth and pushing the wheel in.
Old Mar 15, 2006 | 01:09 PM
fmrprojects's Avatar
Default Re: (shredder22)
they are gonna break. just put a big breaker bar on it. then you need to replace the studs
dc2luva
Apr 10, 2009 03:45 PM
dre2day
Feb 16, 2008 07:56 AM
JDM_EK4_Coupe
Nov 21, 2006 07:42 PM
wagonis
Jan 26, 2005 12:25 PM
LudeyKrus
Jul 26, 2004 10:42 AM
