HELP - issues with a teggy swap CEL 16
Old Mar 15, 2006 | 12:05 PM
BigJ5's Avatar
Default HELP - issues with a teggy swap CEL 16
Well, my buddy has a 94 teggy with a blown up B20B and a shitty trans. So since I've done swaps before, and had a spare jdm b18b and trans from my old setup, we concluded to swap. The swap went in easy, as always straight swaps do... then the bad....
Start up the car and it's in limp mode
First I had 2 error codes, 16, and 41
the O2, sensor wasn't plugged in all the way, so that code goes away.
So, now I was left with code 16, the fuelling system... so I swapped all the injectors, all injectors accross the board measure 11.9 ohms. Withing tolerence. I start the motor back up and same issue, stuck in safe mode. Code 16....
Getting a little frustrated I call it a night and decide to get another P75, and try it again. Today I picked up another P75, and the same issue, stuck in safe mode with CEL 16. I thought well the cpu gets a lot of info from the dizzy maybe that somehow got damaged, swap that out as well....same error still...
Ok H-T, help me out with this one I'm losing my wits here. What am I missing? There is fuel at the rail, fuel going into the motor, and fuel returning to the tank. What else could be causing this code? My buddy needs his car back to drive to work, and I have better things to do, like work on my car and go to school....damn teggy
Discontained
10
Sep 24, 2006 10:16 PM
jonathan13
Jul 19, 2006 03:19 PM
Lo-Buck EF
16
Aug 22, 2003 05:39 AM
