Steering wheel not straight
Old Mar 15, 2006 | 11:40 AM
skeg8's Avatar
Default Steering wheel not straight
My steering wheel is not straight when the car is going straight. The alignment is fine, it is just the wheel itself. The wheel is about 2/3" right of center.
I think this can be adjusted by the tie rod's but I am not sure how to do it.
Anyone know how to fix this??
Old Mar 15, 2006 | 11:46 AM
yellowrexsi's Avatar
Default Re: Steering wheel not straight (skeg8)
It can be adjusted that way. Problem is if you don't know what you are doing you will mess up the alignment. Best bet is to take it to a alignment shop and have them adjust it for you. They have the equipment to make sure everything stays in spec
Old Mar 15, 2006 | 12:23 PM
TurboEM1's Avatar
Default Re: Steering wheel not straight (yellowrexsi)
2/3". Thats the first time ive heard that. lol
Anyway get an alignment and it will be fine.
Old Mar 15, 2006 | 12:25 PM
q45mm's Avatar
re-align.
Old Mar 15, 2006 | 01:11 PM
fmrprojects's Avatar
Default Re: Steering wheel not straight (q45mm)
is it the stock wheel or a aftermarket. maybe they replaced the steering wheel crooked. if its the stock, go out and get an alignment
Old Mar 15, 2006 | 01:16 PM
skeg8's Avatar
Default Re: Steering wheel not straight (fmrprojects)
It is the stock wheel. It is only slightly off but when I got a new stock wheel I tried to fix it but it was either off to the right or left, never right in the middle. I think I will wait until i get some suspension and then get it all aligned at once and save two trips to the alignment shop.
Thanks for the advice.
easyFOsheezy
Aug 25, 2010 12:26 PM
Diversion
Aug 27, 2006 02:16 AM
.water
Suspension & Brakes
Feb 9, 2006 10:39 AM
zeroluck
Suspension & Brakes
Jan 11, 2006 05:42 PM
lewdude
Sep 28, 2004 10:06 PM
