Lower Motor Mounts ?
Hello all,
My question is, does anybody make a full replacement lower motor mounts? I have searched everywhere and all I find are inserts. But, I can't use my existing lower motor mounts cause they are completely ripped. I'm trying to replace all 5 mounts, I already bought the top 2 and the rear, now I just need the bottom 2. I heard Jimfab made replacement mounts for the lowers but it looks like he's no longer doing them. Am I going to have to buy OEM lower mounts then buy inserts?
Thanks for your imput.
Will the OEM mounts work with the Hasport uppers and rear? I bought the 70A Hasport mounts and thought the lowers would be too soft for these.
The will work fine with the hasport mounts.
They will actually receive less stress because the hasport mounts are already limiting engine movement much more than stock.
If you're worried, just get inserts for the replacements as well...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">Why not just use OEM, http://www.barancoacuraparts.c...dIrno=
Theyre like 30 bucks.</TD></TR></TABLE>
They're $30 EACH!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">12 50841-ST7-Z00 RUBBER, R. FR. 1 2000 INTEGRA 35.60 28.48 Qty:
14 50842-ST7-Z00 RUBBER, L. FR. 1 2000 INTEGRA 35.60 28.48 Qty:
They're $30 EACH!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">The will work fine with the hasport mounts.
Yeah, it looks like this is what I'm going to have to do. I guess the best inserts are the ES, right?
</TD></TR></TABLE>Yeah, it looks like this is what I'm going to have to do. I guess the best inserts are the ES, right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMSpoonType-R »</TD></TR><TR><TD CLASS="quote">
Yeah, it looks like this is what I'm going to have to do. I guess the best inserts are the ES, right?</TD></TR></TABLE>
They were the only ones available for a good long while... have you found an alternative?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GPNY »</TD></TR><TR><TD CLASS="quote">How about you align your torn mounts, and fill them with 3m window weld or Permatex ultra black.
Solid mounts for 10$ and easy to do.</TD></TR></TABLE>
Actually, there is nothing to align it with, pretty much all the rubber was ripped out during the accident. All I have is the outer casing of the lower mount
They were the only ones available for a good long while... have you found an alternative?</TD></TR></TABLE>
Only found 2, the Prothane and Energy Suspension inserts.
Only found 2, the Prothane and Energy Suspension inserts.</TD></TR></TABLE>
Prothane = two uppers and rear
ES = two lower and rear
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">With solid motor mounts who needs the two supplementary mounts?</TD></TR></TABLE>
They still help out a bit.....
Didn't Spoon use to make a set of mounts ?? I think I read something to this effect somewhere ..
UPDATE: Here they are .. Spoon Mounts ..
http://www.ipsracing.com/engin....html
Not cheap by far but hey, they're Spoon blingage !!!
They still help out a bit..... </TD></TR></TABLE>
I beg to differ. The hassport mounts are so stiff that the supplementary mounts would be there to add weight. If they help(which I dont think they do) at all, it wouldnt even be noticeable.
Its interesting that happened to you too. After my accident, I noticed that the Energy Suspensions motor mounts that I had both had broken the zipties and popped out of the mount
I fixed it though.
.</TD></TR></TABLE>
I fixed it though.
Theyre like 30 bucks. </TD></TR></TABLE>
Well, I just purchased these.........
12- 50841-ST7-Z00 RUBBER, R. FR. 1 2000 INTEGRA 35.60 28.48
14- 50842-ST7-Z00 RUBBER, L. FR. 1 2000 INTEGRA 35.60 28.48
I guess inserts are the next step, thanks guys and thanks Len.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommymoose »</TD></TR><TR><TD CLASS="quote">Its interesting that happened to you too. After my accident, I noticed that the Energy Suspensions motor mounts that I had both had broken the zipties and popped out of the mount
I fixed it though.</TD></TR></TABLE>
I've heard with the ES inserts the zipties are pretty weak, how did you fix yours...........with more zipties?
I fixed it though.</TD></TR></TABLE>I've heard with the ES inserts the zipties are pretty weak, how did you fix yours...........with more zipties?
I've heard with the ES inserts the zipties are pretty weak, how did you fix yours...........with more zipties? </TD></TR></TABLE> I am interested in knowing this too! Those zipties suck ***** on the ES kit
I checked ebay, but didn't find anything to my likeing(sp?).............man I wish I could have gotten the Jim Fab ones.
I bought the Hasport (70A) mounts and can't wait to get them on, they told me to expect vibrations.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 »</TD></TR><TR><TD CLASS="quote">
they kinda look goofy but damn i might need one </TD></TR></TABLE>
is it just me or do the spoon mounts look just like the OEM ones?
i have the lower ES mounts and they work great, definately much stiffer, you can tell just by the vibration in the steering wheel at idle.
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 »</TD></TR><TR><TD CLASS="quote">
amen! best ten bucks i spent! sprayed it with a heavy coat of black for that sleeper look. vibration at idle is hardly noticeable... but definitely there for the 1-2 and 2-3 shift
btw, i believe these are called the 'torque mounts'
Thanks guys, ordered the stock lower mounts and just bought the ES inserts.
I hope this along with the Hasport mounts will make for a sweet ride.
Now I need some coil-overs.
Any opinions........Tein Flex perhaps or maybe Buddy Club N+ Spec?
I hope this along with the Hasport mounts will make for a sweet ride. Now I need some coil-overs.
