Shaking/Low Idling
Recently bought a 91 Accord. Very nice except it shakes when at a stop even when warmed up (actually more when warmed up) especially w AC. A guy with a 93 accord told me to let it be. Should I increase the idle manually or just let it shake? Thanks
Idle should be at 750 when warmed up with or without A/C on. if it isn't get it there and then check your motor mounts. They are rubber insert type and will deteriorate with age.
i had the same issue, mine was because it needed a bad valve adjustment, it was way out of spec.
but the mounts are also a more common cause of this, mostly the rear
euclid
71
Jul 13, 2003 06:53 PM
