What do you think of this setup?
Old Mar 15, 2006 | 07:07 AM
j s t n 0 1 2 7's Avatar
Default What do you think of this setup?
In a 2000 civic coupe?
Gsr motor
eagle rods
je pistons
10.6:1 cr
skunk2 cams
skunk2 cam gears
dc 4-1 header
carsound hi-flow cat
apexi n1
hasport mounts
tranny
gsr no lsd
itr clutch
itr flywheel
suspension
tokico Illumina 5-way adjustable shocks
ground Control coilovers
skunk2 front camber kit
comptech rear tie bar
omni Lca's
front strut bar
Old Mar 15, 2006 | 07:44 AM
jdm_ekcivic's Avatar
Default Re: What do you think of this setup? (justin0127)
You could probably bump that compression a little higher.
Also, may as well get the ITR LSD while you are at it.
Old Mar 15, 2006 | 07:51 AM
Chong's Avatar
ballin
Default Re: What do you think of this setup? (jdm_ekcivic)
e-Building?
Old Mar 15, 2006 | 08:01 AM
dreww..'s Avatar
sounds alright, enough talk, lets see it happen
Old Mar 15, 2006 | 08:41 AM
reactone's Avatar
Def bump the comp. if you plan na, otherwise drop it and boost. 10.6 theres no reason for forged internals at that comp ratio.
Old Mar 15, 2006 | 08:43 AM
Chong's Avatar
ballin
Default Re: (reactone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reactone &raquo;</TD></TR><TR><TD CLASS="quote">Def bump the comp. if you plan na, otherwise drop it and boost. 10.6 theres no reason for forged internals at that comp ratio.</TD></TR></TABLE>
I think he plans NA seeing that he did say header, and some s2 cams...
Old Mar 15, 2006 | 08:49 AM
Brodie Bruce's Avatar
Default Re: What do you think of this setup? (Chong)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chong &raquo;</TD></TR><TR><TD CLASS="quote">e-Building?</TD></TR></TABLE>
haha
OP, you mention a comptech tie bar, but no sway bar. Get a big sway bar.
Coricivic
Feb 8, 2015 04:56 PM
third lobe
Sep 13, 2007 11:04 AM
b20vtecEK
Oct 13, 2005 11:49 AM
v00tecsi
Sep 22, 2003 02:57 PM
patdemps
May 13, 2003 07:21 PM
