110v air compressor larger than 30 gal??
Old Mar 15, 2006 | 04:21 AM
stackz's Avatar
at the jetties fishin'
Community Builder
Default 110v air compressor larger than 30 gal??
I'm looking around for an air compressor for use in my apartment's garage. the largest I can find are 30 gallon uprights. everything else is 220 or higher. I'd just ghetto rig it and run a long *** 6-3 air conditioning wire to my drier outlet but...well...it would be about 50ft long AND the girlfriend wont approve either
anyone know of any compressors that are larger and still 110v??
I've actually thought about just buying a 220 unit and then just buying and retrofitting a damn 110v motor from grainger. I wonder how this would work?? dont see why it wouldnt???
oh also, what psi output rating should I look for if I want to do grinding/port work/and some paint/body work??
I'm waiting until I purchase the compressor before I start looking at airtools is why I ask.
Old Mar 15, 2006 | 11:04 AM
8mpg's Avatar
Default Re: 110v air compressor larger than 30 gal?? (stackz)
just buy a bigger tank...wont always keep up but you will have a ton of air to begin with.
Old Mar 16, 2006 | 03:35 AM
stackz's Avatar
Community Builder
Default Re: 110v air compressor larger than 30 gal?? (8mpg)
anyone know if my idea of buying a 220v compressor and then just retrofitting a 110v motor onto it will work??
Old Mar 16, 2006 | 03:45 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stackz &raquo;</TD></TR><TR><TD CLASS="quote">oh also, what psi output rating should I look for if I want to do grinding/port work/and some paint/body work?</TD></TR></TABLE>
who cares about PSI.. You're going to suck back the CFM like a $2 ***** with the bodywork/grinding tools you listed.
Old Mar 16, 2006 | 06:13 AM
stackz's Avatar
Community Builder
Default Re: 110v air compressor larger than 30 gal?? (2point2)
because obviously with a higher psi I can run a higher rated grinder, etc.
not to mention I think there's like a minimum psi output for most air tools...just cant find any specs when I look online at the tools is all but I know they post it on the box.
Old Mar 16, 2006 | 07:04 AM
8mpg's Avatar
you have to have like 90psi which any compressor will do...its the CFM (amount of air flowing) that you cant handle with a 110v.
its not worth retrofitting...
MugenEg
Paint and Body
Jan 7, 2010 09:28 AM
punkinbeck
Paint and Body
Aug 22, 2008 02:24 PM
komat
14
Dec 24, 2004 07:09 PM
dabrown
Mar 15, 2004 09:01 AM
mikecel79
Apr 28, 2002 09:36 PM
