daily driver sohc v-tec
my car is a 96 ex im not to familiar with makin d-seris a little more faster and reliable to drive i know alot about b-seris its so simple to make power but i dont want a swap it costs way to much to do and to much time to swap please help I need ideas
how much are you willing to spend your engine has lower compression for turbo than a b series
turbo- $1000- $3000
there are many already made kits for your engine (greddy apexi edelbrock)
that come with bigger injectors/intercoolers/and engine mangement and you can run about 8psi reliably so about 170-190 to the wheels
or you can make a custom one
b16a/gsr- 2000-3000
very reliable 160/170 out of the box (but not to the wheels)
higher compression
turbo- $1000- $3000
b16a/gsr- 2000-3000
higher compression
thanks but after posting this thread last nite im going to go with a b 20 motor. b20z it has higher compression as for the b20b its much better for turbo because it low compression i really love tourqe and i want turbo maybe just a t3 nothing dramatic but thanks for info. I have a lot of thinking to do
You would be better off going with your sohc turbo. B20 motors are like the worst motor you can boost, so good luck with that lol. Sounds like you need to do some more research before you make any decisions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass »</TD></TR><TR><TD CLASS="quote">You would be better off going with your sohc turbo. B20 motors are like the worst motor you can boost, so good luck with that lol. Sounds like you need to do some more research before you make any decisions.</TD></TR></TABLE>
very true. you gotta read, read, and read some more...
thats probably one of the key things here, know what you're doing.
88hbz6
Nov 25, 2008 07:48 PM
tcb18c5crx
Jan 15, 2004 01:43 PM
