1987 Integra wont start after 2 months and repair...
Hey so 2 months ago this integra broke the timing belt and bent 6 valves.
I fixed everything and put it back together with brand new parts but she wont start.
Injectors are firing
spark is there (firing order checked against FSM and visual check on spark)
compression is good and timing is good.
what could be the cause? I've been hearing stuff about main relays going bad? i donno i'm new to this car. It ran great before the timing belt broke. it was only sitting for 2 months
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kraig8 »</TD></TR><TR><TD CLASS="quote">im sure you checked this but if the engine ground isnt connected to the chassis it wont start. </TD></TR></TABLE>
everything is connected
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lauj87 »</TD></TR><TR><TD CLASS="quote">try moving the distributor around in different positions...timing might be off. </TD></TR></TABLE>
i marked it when i removed it. also that shouldn't cause a no-start
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs »</TD></TR><TR><TD CLASS="quote">NEVERMIND!
Nevermind guys i just did a compression test:
0-0-150-150
seems as if the head shop didn't do something right.... expletive </TD></TR></TABLE>
....OWNED! lol..better get you **** fixed for free now!
0-0-150-150
92integraVTECgsr
Jul 24, 2007 07:41 PM
