help car bogging,then dies
Old Mar 14, 2006 | 07:42 PM
NoSwapNoCare's Avatar
Default help car bogging,then dies
ok so my beater hatch ran decent
every once in a while it bogged at very low rpms and when i was turning, but all in all it was anon-issue becuz it drove fine the rest of the time
yesterday drove it to school, drove perfect, start it up at night, drive it down the road and its bogging like crazy slows down not getting any gas when i hit it, stalls, tuen the key cranks but doesnt start, wait 2 minutes, crank it, starts up drive tio down the road back to my house, drives fine for a min, the does it again. cel comes on when it stalls, i get it to my house, start it up idles for 2 minutes perfectly, then dies again.
what is this problem?
cannt check cel becuz it goes off once the car dies, and isnt on when it idles
HELP MEEEEEEEEE
Old Mar 14, 2006 | 08:26 PM
jdeemseerx's Avatar
pull back your carpet on the passenger side where your feet would go if you were sittin in the p/s seat, youll see a plate with 4 10 mm around it take those out and your ecu is under it.. the l.e.d. should still be on bc the code will be in memory..if im correct and it is still in memory you have to jump the 2 pin connector uder the right hand side of your glovebox..its got a blue plug and it doesnt go to anything youll see what i mean.. jump it with a piece of wire and turn the key then count how many times it blinks and thats your code
ef9alldatime
13
Sep 12, 2007 04:56 PM
K-Spec
Apr 4, 2006 02:42 PM
oilguzzler
Dec 19, 2005 08:32 PM
serious
Sep 27, 2002 12:06 PM
hydroflip
Jul 30, 2002 02:09 PM
