How long does it take to change the water pump on a h22 prelude?
Old Mar 14, 2006 | 06:36 PM
Scrapin4DR's Avatar
Default How long does it take to change the water pump on a h22 prelude?
well, my water pump took a **** on me sunday night. so me and my mechanic buddy are gonna replace it and while everything is apart i'm gonna replace the timing belt, t-belt tensioner, idler valve pulley, valve cover gasket etc. soo, i wanna know how long does it usually take to replace the water pump since we gotta do this outside cuz 4 of his garages are full and i aint got one. for the tools, he's got **** load of them, engine hoist, racing jacks, jack stands all kinds of bullshit. he's into chevys n **** so he really doesn't know how long will this take and neither do i , so help me out, if it's in the wrong forum , plz move it, thanks
Old Mar 14, 2006 | 07:16 PM
BB6racer's Avatar
took me about 2 days worth of work. just make sure you know how to set the timing and everything when you put the new timing belt on. you should also replace the balance shaft seals, cam seals, and crank seal. the hardest part will be breaking loose the crank pulley bolt and resetting all the timing stuff, and once you get those the rest is pretty simple. good luck, and have fun.
Old Mar 14, 2006 | 07:21 PM
Scrapin4DR's Avatar
Default Re: (BB6racer)
thanks man, it shall be fun haha
Old Mar 14, 2006 | 07:26 PM
petern101's Avatar
Default Re: (Scrapin4DR)
i hope you have a helms/shop manual/a really good writeup
Old Mar 14, 2006 | 07:27 PM
SteveoBA8's Avatar
Snag a balance shaft seal retainer while your in there $3, TSB for seal popping out.
Old Mar 14, 2006 | 07:30 PM
Scrapin4DR's Avatar
Default Re: (SteveoBA8)
no manual i might get one of those autozone books, i couldn't find any write ups either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 &raquo;</TD></TR><TR><TD CLASS="quote">Snag a balance shaft seal retainer while your in there $3, TSB for seal popping out.</TD></TR></TABLE>
TSB seal for poppin out?? care to explain?
Old Mar 14, 2006 | 07:35 PM
SteveoBA8's Avatar
TSB=tech service bulletin, the balance shaft seal will work itself out of the bore causing a huge oil leak=grenade engine.
a $20 chiltons manual will have everything you need for w-pump,t-belt, b-belt removal/install ect.
Old Mar 14, 2006 | 07:38 PM
h22chilton's Avatar
* B A N N E D *
chilton manual=money in my pocket. . . .
j/k
but have fun, quite the task w/ the motor in the car I'd assume, i only mess w/ that stuff one its on a stand!
Old Mar 14, 2006 | 07:58 PM
Scrapin4DR's Avatar
Default Re: (h22chilton)
damn , yeah the engine is in , we gotta jack it up on one side , should be fun and expensive , anybody wanna buy the whole car lol
Old Mar 15, 2006 | 03:38 AM
Scrapin4DR's Avatar
bump for more info
JasonYo
Mar 22, 2010 08:52 AM
S2KILLA
Aug 3, 2006 07:45 AM
idriveadelsol7
Dec 8, 2005 06:00 AM
242 Accords
Nov 22, 2004 10:52 PM
Origin
Nov 15, 2003 09:33 PM
