will ls exhuast fit 98 gsr?
Old Mar 14, 2006 | 06:12 PM
str8drift's Avatar
Default will ls exhuast fit 98 gsr?
a guy a ht has a stock exhuast from a 95 rs integra. will the catback work on my 98 gsr? i just moved to kali. and i need this to fit in order to smog
Old Mar 14, 2006 | 06:41 PM
orangebarius's Avatar
Default Re: will ls exhuast fit 98 gsr? (str8drift)
NO
Old Mar 14, 2006 | 06:44 PM
str8drift's Avatar
why?
can i cut it shorter to make it work?
Old Mar 14, 2006 | 06:55 PM
champLSinteg's Avatar
You can smog with your exhaust unless you dont have a right cat. I have a catback and have smogged it with no problems.
Old Mar 14, 2006 | 08:29 PM
teggy182's Avatar
Default Re: will ls exhuast fit 98 gsr? (champLSinteg)
agreed as long as theres no cels and your running a good cat you should be fine
Old Mar 15, 2006 | 06:08 AM
Default Re: will ls exhuast fit 98 gsr? (teggy182)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by str8drift &raquo;</TD></TR><TR><TD CLASS="quote">why?
can i cut it shorter to make it work?</TD></TR></TABLE>
it is going to be 4 inches too long. so yes, you can cut it and have it welded.
Old Mar 15, 2006 | 07:28 AM
Padawan's Avatar
Darth ModerVader
Default Re: will ls exhuast fit 98 gsr? (orangebarius)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orangebarius &raquo;</TD></TR><TR><TD CLASS="quote">it is going to be 4 inches too long. so yes, you can cut it and have it welded.</TD></TR></TABLE>
Actually, if you are trying to install an LS exhaust on a '98 GS-R, it will be too short, so you would need to have the B-pipe extended by approximately 4", not cut.
Old Mar 15, 2006 | 07:30 AM
Micha's Avatar
FAILWGN
Default Re: will ls exhuast fit 98 gsr? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
Actually, if you are trying to install an LS exhaust on a '98 GS-R, it will be too short, so you would need to have the B-pipe extended by approximately 4", not cut. </TD></TR></TABLE>
Isn't it 2 inches longer for the B pipe? The header is also 2 inches longer on the GSR.
Old Mar 15, 2006 | 07:38 AM
Padawan's Avatar
Darth ModerVader
Default Re: will ls exhuast fit 98 gsr? (Blu99teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blu99teg &raquo;</TD></TR><TR><TD CLASS="quote"> Isn't it 2 inches longer for the B pipe? The header is also 2 inches longer on the GSR. </TD></TR></TABLE>
The GS-R header is shorter than an LS header, not longer.
Old Mar 15, 2006 | 07:45 AM
Micha's Avatar
FAILWGN
The GS-R header is shorter than an LS header, not longer. </TD></TR></TABLE>
This http://www.team-integra.net/fo...20112 says that you are an effin genious.
Old Mar 15, 2006 | 10:25 AM
JDMC-Kamel's Avatar
word
Old Mar 15, 2006 | 10:34 AM
Lauj87's Avatar
california law is..must have a cat and muffler..thats it...but there are little catches to it as well...must be no louder then 900 DB.
Old Mar 15, 2006 | 11:32 AM
str8drift's Avatar
i have an apex N1 exhuast but i do have the silencer...if i just put the silencer on can it pass? see... i have to go to the ref inspectior because my car is outta state.
Old Mar 15, 2006 | 11:50 AM
Lauj87's Avatar
you should be able to pass..as long as you have a cat and a muffler....you might be able to get away with a scilencer depending on the ref.
Old Mar 15, 2006 | 11:55 AM
str8drift's Avatar
thank you very much for your info guys
Rcp
Dec 7, 2005 01:28 PM
mskibbz-T
Mar 6, 2005 04:06 PM
xiLLtegRax
Jan 17, 2005 07:10 PM
1998teg
Oct 19, 2004 04:42 AM
morepoop4u
Sep 8, 2003 12:35 AM
