Gauge problem
I just bought a 94 civic with Si-R gauges in it. When I bought it they gave me the original gauges that came with it. I needed to install them so I could get the emissions test on it. Well my brother thiught he would help me out while I was out work and swapped them for me. But he forgot to disconnect the battery and something happened. After he swapped the gauges my turn signals won`t work now and the car stays running after you turn it to shut it off and you can take the keys out and it stays running. Well I figured out that if I take the hazard switch out it will shutoff. But still no turn signals. I can drive the car and shuts off normal but I relly need my turn signals and hazards also. Could it be a fuse or something? I tried swapping it back but the Si-R gauges but did the same thing. Any help would be greatly appreciated.
same thing happend to me a month ago.
i forgot to connect the plug behind the hazard switch. if that plug isnt pluged in, u dont have turn signals nor hazard signals.
so check to see that u got that pluged in. and if it is pluged in, maybe there is a shortage in the wires goin into that plug. thats all i know.
Mugen1320
Feb 4, 2009 05:26 AM
Mr. Em1
Feb 26, 2008 10:37 AM
