91 Speedo Cable
Old Mar 14, 2006 | 05:16 PM
93egryda's Avatar
Default 91 Speedo Cable
Need help getting the new cable into my car what is the easies way to do it beside having a shop do it..
Old Mar 15, 2006 | 10:25 AM
RaceCarRyne's Avatar
Default Re: 91 Speedo Cable (91da6ryda)
easiest way is to take out the dash.. if you dont wanna do that then you just have to spend some time fishing it through the hole..
Old Mar 15, 2006 | 11:16 AM
Rikter's Avatar
This topic was just covered.
1) Open Hood, remove speedo cable from your trans (one clip). This is located on your trans just down from the distributor and a bit to the side)
2) Take your dash apart to get at the cluster (various hidden screws behind panels, etc etc. Have fun. It sucks)
3) Because you took the speedo cable out of the trans you can now pull the cluster out a good distance so you aren't struggling to get your hand behind the cluster
4) Unclip the speedo cable.
5) I just cut mine in half and pulled one half on one side out and one side on the other side of hte firewall.
6) Feed the cable through firewall (insert grommit in firewall). Attach cable to cluster, re-install cluster and bezels.
7) Attach cable to trans (one clip). You should then be good to go
This is basically it. Good luck
-Rik
93grayeg
May 20, 2011 10:35 PM
Gawear
Jun 19, 2010 08:22 AM
peanut butter
Feb 18, 2008 04:00 PM
da9blk1
Sep 5, 2007 11:10 AM
cutt
Nov 12, 2004 06:57 PM
