help I just hit a curb!!!!!!!!
Old Mar 14, 2006 | 04:29 PM
korney's Avatar
Default **update** help I just hit a curb!
well guys!!! its offical!!! my car is in the shop getting fixed! and it will only cost me about 400 dollars or under! I took the lude to 4 shops, had an estimation at the 4 shops and all but one shop said all the same thing. The shop that said it would cost 400+4-500 labor was trying to rip me off.
The other 3 said the same thing, only the cradle was bent, the shop thats fixing my car had me look at it and he explained everything step by step, all my suspension is FINE only the cradle is bent and shoved to the left. that is why the wheel looks like that. But I do indeed need a whole rear suspension, or if anyone here is selling a cradle I'll buy it from them.
It should take only about one week to get everything fixed. waiting on just the parts, from a local junkyard
all for under 500 bucks!
Modified by korney at 7:03 PM 3/21/2006
Old Mar 14, 2006 | 04:34 PM
korney's Avatar
Default Re: help I just hit a curb!!!!!!!! (korney)
help me please!!!! my car is not drivable anymore!!! just comeing home I can smell the tires burning!!!
Old Mar 14, 2006 | 04:37 PM
korney's Avatar
help!!
Old Mar 14, 2006 | 04:38 PM
lostkoz's Avatar
huh...no shop u ask buy a new one
AnthonyG2003
Guest
Posts: n/a
How can you fix it without taking it to the shop?? Jack the back end of your car up and see if there is anything visibly bent or warped.
Sorry to hear it man...
Old Mar 14, 2006 | 04:41 PM
hu's Avatar
hu
Worst case scenario is you will have to buy a new wheel and tire. Take it off and do an inspection. Hopefully, there isn't further damage.
Old Mar 14, 2006 | 04:43 PM
korney's Avatar
Default Re: help I just hit a curb!!!!!!!! (AnthonyG2003)
i did take the tire off and looked and nothing visible seems to be bent or anything, but it is dark out...ohh ****, I just hope I dont have to replace the whole fucken axel...damn!!.... the i think that the brake is bent inward can i just take a hammer and bash it back out?? anyone know how much it will cost? can i just get an alinment on the back axel or anything?
Old Mar 14, 2006 | 04:44 PM
The Weather Man's Avatar
yeah. Most likely, your wheel bearing just got f'ed up. Along with whatever is wrong.
Take off the wheel - first see if its bent. If not:
Inspect the suspension components. Make sure your spindle is straight and everything.
Hey, before you take off the wheel, see if it moves up and down or left to right. If it moves in and out - the wheel bearing is messed up.
Hey. How the expletive did you hit a curb anyway? If the wheel looks like /-----|
Speedin are we?
Old Mar 14, 2006 | 04:48 PM
korney's Avatar
Default Re: (The Weather Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Weather Man &raquo;</TD></TR><TR><TD CLASS="quote">yeah. Most likely, your wheel bearing just got f'ed up. Along with whatever is wrong.
Hey, before you take off the wheel, see if it moves up and down or left to right. If it moves in and out - the wheel bearing is messed up. </TD></TR></TABLE>
no nothing moves at all it just seems like the brake is bent thats all, its like bent like this // can i just use use a hammer? and bash it outward again?
Old Mar 14, 2006 | 04:51 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: (korney)
you can try anything...if it is fucked up now...it will be fucked up when you are done weather you do that or not...but it might even fix it.
Is your rotor and everything straight? Maybe the "/" is an exaggeration?.............
You mean the caliper is tilted like / this?.............
pull all of that off and inspect everything to make sure its straight. It could be the braket that holds the brake pads on. But that wouldn't affect your wheel. If your wheel is bent like that - something is definately wrong. Can you take pictures at all?
Old Mar 14, 2006 | 04:53 PM
korney's Avatar
yes sorry thats what i mean the rotor is like this / can anyone tell me or have an idea what is wrong?
Old Mar 14, 2006 | 04:55 PM
Wheel hub could be bent. Tkae off the middle cab and see how far the nut is. You could have bent the wheel hub - which would be hard to do.
Tkae out the two retaining screws off the rotor and pull it off the hub. Might have to use a hammer to beat it off kinda - use a mallet.
Old Mar 14, 2006 | 05:00 PM
korney's Avatar
awww ****, i cant do this right now... its fucken late and windy and fucken cold! damn.... so is that the problem? the wheel hub is bent? is this hard to do? can i just use a mallet to bash the rotor back into place?
Old Mar 14, 2006 | 05:01 PM
lostkoz's Avatar
yeah check ur suspension out that **** bends nicely it happen to my car when this shop jump a curb n my car.
this is what a shop told me that's what they do,try cutting a template of the diameter rim slid it up and down see if it touches.
yeah hard to tell but that's a bent sway bar and tie rod
&lt;img src="http://img481.imageshack.us/img481/4448/car2238kd.th.jpg" border="0" alt="Free Image Hosting&lt;A HREF="http://img481.imageshack.us/my.php?image=car2256tu.jpg" TARGET="_blank"&gt; at http://www.ImageShack.us" /&gt;&lt;/a&gt;
Old Mar 14, 2006 | 05:02 PM
NO! You cannot use a hammer to bash the hub back in place. You NEED to buy a new one. And while you're at it - get a new rotor and brake pads. Its nothing you can hammer back in place. Seriously. The bearing is probably messed up also - and you'll start to hear a LOUD clunking sound in a few days.
Old Mar 14, 2006 | 05:09 PM
korney's Avatar
****....i really don't think that its that bad... just that its fucken bent inward...isnt there a nut or somthing i can losen to make it stright again?
Old Mar 14, 2006 | 05:13 PM
lostkoz's Avatar
you could try, bit u really think it will b true again. if $$$$ is low for new parts hit up some junks yards man...bent iz bent
Old Mar 14, 2006 | 05:20 PM
korney's Avatar
Default Re: help I just hit a curb!!!!!!!! (lostkoz)
**** i dont have much money and time, Im still in school and I work also and plus a girlfriend... can i just try to hammer slowly the rotor into place? do you think that the shop can do it? i really dont want to replace anything...
Old Mar 14, 2006 | 05:26 PM
korney's Avatar
any real Mechanics in here that can help me?
Old Mar 14, 2006 | 05:32 PM
Man what the expletive are you talking about?
There are no short cuts. And any REAL technician isn't going to tell you to hammer it back. When you bend metal, then bend it back - guess what! It develops a very weak spot, if it doesn't break already.
Hammer it if you want - but if you make a sharp turn, and it breaks - don't get mad at us. It doesn't take a lot of time to pull off the hub. Its just one nut. Then it pulls off. Thats it.
Old Mar 14, 2006 | 05:33 PM
hu's Avatar
hu
Theres no easy way out. You said its bent. If you don't believe any of us, get a hammer and go to work. We have no reason to lie or mislead you. If $ it tight go to a junk yard or search online for used parts. You should be able to file this with your insurance. Just pay the deductible.
Old Mar 14, 2006 | 05:35 PM
94Vtecluder's Avatar
Dude if you wheel is bent in you have some SERIOUS problems. It won't be an easy thing to fix, and you probaly bent something. I had a similar experience with my front driver side tire. I hit a curb and the front tire was bent in. I needed a whole new suspension setup for the front driverside tire costing around 450 or so to fix and get it aligned. Woulda cost more if I didn't find someone parting our their lude. So no an alignment alone will not fix that and they probaly won't even be able to align it. Sorry man, be ready to shell out some bucks, you going to have to take it to shop.
Old Mar 14, 2006 | 05:37 PM
cruzin89lude's Avatar
yeah... if i were cheap as hell like you, i'd use the laws of physics. Equal and opposite reactions undo stupid actions like hitting curbs. So you need to aim for that same curb, but hit it this time twice as fast and at the opposite part of the wheel. this should put everything back where it should be. good luck man.
Old Mar 14, 2006 | 05:40 PM
korney's Avatar
Default Re: (94Vtecluder)
sorry guys, im just kinda pissed thats all, i really aprecatie all your guys help a lot... so there is no easy way out? im gonna have to take it to the the shop huh? ok well yes the rotor is just bent is there like a arm bar or something i can replace it with?
