Lost Motion Assemblys - What/Why?
Old Apr 1, 2002 | 12:21 PM
reefer_bob's Avatar
Default Lost Motion Assemblys - What/Why?
Basically what the topic says. I have a GSR, that I'm looking to put some cams in (not sure which yet), but I keep reading about people saying to put in the ITR LMA's... What do they do, where are they located in relation to the cams, does the GSR have them, and the ITR's are better, is there anything else associated with putting them in, and why do I want to spend the extra money. Thanks!
Reefer_Bob.
Edit: The search sucks.
[Modified by reefer_bob, 1:22 PM 4/1/2002]
Old Apr 1, 2002 | 12:22 PM
sgT's Avatar
sgT
Default Re: Lost Motion Assemblys - What/Why? (reefer_bob)
the LMA keeps the vtec rocker arm in place so that vtec can engage.
The bigger the cam, the stiffer LMA you will need, and ITR LMA is the stiffest
available to my knowledge.
Old Apr 1, 2002 | 12:25 PM
ZygSpeed's Avatar
Default Re: Lost Motion Assemblys - What/Why? (sgT)
Weren't there some Ti pieces available for these things some time back? (and no I don't mean the retainers, one of the VTEC spools or something).
reefer_bob's Avatar
So then, if I were to do something as simple as put in ITR cams, are the ITR LMA's highly recommended? Something bigger Toda/Jun/whomever a must have? Is there a good rule of thumb? Thanks!
Reefer_Bob.
Old Apr 1, 2002 | 12:34 PM
sgT's Avatar
sgT
zygspeed: DPR used to sell Ti VTEC Pins that go in the rocker arms
With ITR cams you may not need them. for larger cams DEFINITELY
Old Apr 1, 2002 | 01:58 PM
Black R's Avatar
25 Year Member
.....I wonder if some roller rockers would free up some whp for us.....
Old Apr 1, 2002 | 07:29 PM
t's Avatar
t
Wouldnt the Ti Pins gall the hell out of the rockers??
Old Apr 1, 2002 | 07:38 PM
SCsol's Avatar
Default Re: Lost Motion Assemblys - What/Why? (t)
GSR and ITR have the same LMA there the same part number
Old Apr 1, 2002 | 07:54 PM
NC-B17A's Avatar
Default Re: Lost Motion Assemblys - What/Why? (lowsol)
Yes the ITR & GSR Lost Motion Assemblys are the same.
Old Apr 2, 2002 | 08:46 AM
reefer_bob's Avatar
Default Re: Lost Motion Assemblys - What/Why? (NC-B17A)
Ok, I'm confused here... First SgT says to upgrade to ITR's with bigger cams, but now multiple other people are saying they're the same... Hmmmm.....
Reefer_Bob.
Old Apr 2, 2002 | 11:17 AM
SCsol's Avatar
call acura and get the part numbers to know for sure!!!
also will the lost motion assemblys make noise if there worn out sort of like a valve that needs ajustment!
Old Apr 2, 2002 | 12:02 PM
sgT's Avatar
sgT
That would be incredibly odd since all the ITR LMAs I have seen have been marked
whereas others were not. Also they were noticably stiffer. Very noticable difference
when idling on the BIG cams. I havent checked part numbers myself, but i seriously
doubt it.
Old Apr 2, 2002 | 05:24 PM
b19coupe's Avatar
Lost motion assembly part numbers:
GSR---14820-P30-010
Type-R---14820-P73-J01
Suggested retail:$36.50 each (both are the same price).
A type-r LMA is definitely stiffer.
BG-Teg
Mar 1, 2007 02:02 PM
JDMkidGSR
Sep 8, 2005 05:50 PM
candymanjl
Sep 6, 2005 08:44 AM
KustomCrx
Oct 24, 2004 10:27 PM
1fastGSR
Aug 7, 2001 06:14 PM
