Cam Cap Bolt ?
are the GSR and LS camp cap bolts (the 4 10mm ones) the same? the LS are 6x40 the GSR are 6x45, would there be any problems using the LS in the GSR? LMK Asap cause i really need to get my car running. THX!
Modified by OZ Rally at 2:20 PM 3/14/2006
they are different.
here's the part # for that bolt
95701-08050-00
its #32 in the pic
there are 16 #32's and 4 #20's. #20 is the longer valve cover stud/cam cap bolt.
95701-08050-00
its #32 in the pic
I wouldn't. If they come up too short, you'll tear the threads out of the head. They're so cheap that I don't know why you wouldn't want to just buy new ones from a dealership or even from a hardware store.
you were talking about 16 and 17? then they are the same bolts, i in fact did this.
here are part numbersm they are smaller in fact from the LS head... but you can use em though.
ls
#10 90003-PH3-000
#11 90002-PH3-000
#8 90003-PG6-000
vtec b
#16 90002-PJ7-010 6*45
#17 90002-PR3-000 6*55
hope this helps.
Modified by 4sd4dr at 4:39 PM 3/14/2006
ls
#10 90003-PH3-000
#11 90002-PH3-000
#8 90003-PG6-000
vtec b
hope this helps.
EK FLY
24
Feb 14, 2005 06:00 PM
