Brake Problems... :(
i got a problems with my 1989 b16a crx si. My problem is that i have a really hard time braking when i go pass 55+mph. I have changed my brake and bleeding brake fluid. When i try to brake on the highway my steering wheel shake continuously. Do u guys have any idea what the problem is?
that used to happen to me with my eclipse. your rotors might be warped or the surface of them may be un-even. have the rotors re-cut so that they will be perfectly flushed against the brake pads.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaCRXboi »</TD></TR><TR><TD CLASS="quote">how could u tell? i checked it the other day, it looked just fine when i was changin my brake.</TD></TR></TABLE>
because were smart
get new rotors
because were smart
get new rotors
Because looking at them does not tell you if they are warped or unparallel. You need a micrometer and dial indicator for that. Shaking at highway speeds while braking is a rotor problem. I would suggest getting new ones like brembo blanks or autozone blanks. Make sure you break in the pads correctly also.
NammyBoy
11
Nov 29, 2002 12:00 PM
