97 teg won't go into ANY gears!!! HELP!!
Old Mar 14, 2006 | 10:24 AM
Flex1's Avatar
Default 97 teg won't go into ANY gears!!! HELP!!
None of my gears will engage if I have the car on while the clutch is pushed in. I turn off the car, put it in 1st gear, and start the car with the clutch in. th car starts doing, what i call the crazy dance, which is as if the car was stalling hard. So we figured it might be the slave cylinder. Replaced it, bled the clutch, and same thing. My buddy asked me if the "Master clutch Cylinder" was leaking, so I checked(BEHIND THE CLUTCH PEDAL, IF IM COREECT) and sure enough, it was leaking. The funny part, I really never noticed when I checked the clutch fluid resevoir. Could the Master Clutch Cylinder not let the car go into gear when the engine is running??? ANY HELP APPRECIATED!! THANKS!!
Old Mar 14, 2006 | 12:27 PM
KeithsDAteg's Avatar
Default Re: 97 teg won't go into ANY gears!!! HELP!! (Flex1)
Well you pretty much answered you own question. Just replace your leaking Master Cylinder, and that should fix it.
Old Mar 14, 2006 | 01:03 PM
Flex1's Avatar
Default Re: 97 teg won't go into ANY gears!!! HELP!! (KeithsDAteg)
Just wanted a 2nd opinion......Thanks!!
and that would be my Master CLUTCH Cylinder, right?This is my first integra and I TRY to do all my own work, and I always like to get a 2nd opinion. you never know!
Old Mar 14, 2006 | 01:07 PM
ZipTieGUy's Avatar
your master cylinder MAy be bad, but the symtoms you have point to a worn out clutch
Old Mar 14, 2006 | 01:21 PM
Flex1's Avatar
Default Re: (ZipTieGuy)
GREAAAAATT!! I should just replace the whole clutch system then.....140k miles, i've already changed the slave cylinder, clutch does feel replacement, and most def the Clutch Master Cylinder because it's leaking from behind the pedal.....any other suggestions??
Old Mar 14, 2006 | 01:22 PM
super jdm yo's Avatar
i had the same problem, but mine was that the springs off the clutch came off. and was hitting up againist the pressure plate.
Old Mar 14, 2006 | 01:31 PM
Flex1's Avatar
Default Re: (trkd_out)
I'll replace the clutch master cylinder and see what happens from there.....
Old Mar 14, 2006 | 02:09 PM
Flex1's Avatar
Default Re: (Flex1)
...and the clutch disc.
sounds more logical how a spring can break and get stuck in between the plate and letting the clutch engage.....
Old Mar 14, 2006 | 03:50 PM
Default Re: (Flex1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flex1 &raquo;</TD></TR><TR><TD CLASS="quote">Just wanted a 2nd opinion......Thanks!!
Well I gave you my opinion....So, chill with the attitude!
Regardless the outcome. If you replace the Clutch Master Cylinder and it still doesnt solve the problem... At least you wont have the leaking CMC!
Old Mar 17, 2006 | 08:31 AM
Flex1's Avatar
Default Re: (KeithsDAteg)
Chillax homie, no attitude here..... the extra "!!" was for the "thanks". Anywho.....
It was most def the spring on the clutch disc. Spring broke off and got stuck between the clutch disc and pressure plate (thank's Ziptie Guy). Soooooo, i got a new Stock Exedy Clutch Kit, and replace the slave cylinder, and the clutch master cylinder. Thanks for the help and advice guys, GREATLY APPRECIATED!!
HAVE A HAPPY DRUNKEN ST. PATTY'S DAY!! BE SAFE & WEAR A HAT DAMMIT!!
madeinchina
Transmission & Drivetrain
May 16, 2011 12:38 PM
96WhiteOnBlack
Mar 26, 2007 07:15 AM
lo0nY
Feb 26, 2006 03:58 PM
mdj_ge
Dec 3, 2004 06:45 AM
