clutch pedal
Old Mar 14, 2006 | 09:46 AM
delontew's Avatar
Default clutch pedal
what is the lowest i can have my pedal adjusted to w/stge 3 clutch on a 96 accord?
Old Mar 14, 2006 | 11:17 AM
AFAccord's Avatar
Default Re: clutch pedal (delontew)
Bump. Was curious as well, though I'm satisfied with my pedal's adjustment since being in the middle as it is, I'm sure it's fully disengaging and fully engaging as I depress the pedal. Didn't want to mess with that without knowing.
Old Mar 14, 2006 | 11:29 AM
NAiL05's Avatar
You can adjust it as low as you want even though it is not recommended. You adjust too low you will not be able to put the car in gear. I have my pedal about midway and it works just fine.
Old Mar 14, 2006 | 11:34 AM
AFAccord's Avatar
Default Re: (NAiL05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAiL05 &raquo;</TD></TR><TR><TD CLASS="quote">... adjust too low you will not be able to put the car in gear. </TD></TR></TABLE>
That's what I was speaking of. Too low, and it might not disengage the clutch enough to shift into gear, or cause grinding during a quick shift. Too high, and the clutch might not engage completely, causing it to slip. This is what the original poster has to work around.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAiL05 &raquo;</TD></TR><TR><TD CLASS="quote">You can adjust it as low as you want...</TD></TR></TABLE>
Not a viable answer.
Old Mar 23, 2006 | 04:10 AM
delontew's Avatar
Default Re: (AFAccord)
yeah to oem specs, its got maad play. when its low its has the sickest engagement, but it slips after not long when it gets hot. i even took it somewhere just make sure n the same thing he told me. sux. but everybody else i let feel it says it feels good?
98R-1144
Jun 27, 2008 07:40 AM
k_lude
Jun 19, 2007 08:19 AM
All Motor Ek99
Apr 8, 2005 06:51 AM
_Endless_
Sep 4, 2004 02:46 AM
