Interior wiring question about EG/DC2
Old Apr 1, 2002 | 11:16 AM
nfn15037's Avatar
Default Interior wiring question about EG/DC2
I am getting ready to swap everything from my GSR over to an EG. My question is: The hatchback i got has no witing at all in it. I plan on using my GSR dash also. Is it possible to just swap over the whole wiring harness from my GSR? I have most everything else figured out, but this is the last minor thing. Any help would be greatly appreciated!
Old Apr 1, 2002 | 11:54 AM
bigblockEG's Avatar
Default Re: Interior wiring question about EG/DC2 (nfn15037)
The best way to do it would be to swap the whole dash and harness over. If you are using the teg dash, that means you will have easy access to the teg harness, and you will be able to take the stock civic one out easily too. When you swap the dash over, use every nut and bolt. Bring over your airbags sensors and everything. You will have no wiring problems if you use the entire gsr harness in and out.
Old Apr 1, 2002 | 01:56 PM
nfn15037's Avatar
Default Re: Interior wiring question about EG/DC2 (bigblockEG)
Sweet, thanks for the info! Thats perfect since the hatch is completely bare. I can use EVERYTHING from the GSR is what you are saying. All the wires etc?
Komyo
Jan 12, 2014 06:36 AM
rev210k
Apr 17, 2006 04:41 PM
