quick question about clutch bleeding
Old Mar 14, 2006 | 07:53 AM
aznsins88's Avatar
Default quick question about clutch bleeding
i had already found 2 articles about bleeding the clutch
Link 1 https://honda-tech.com/zerothread?id=255545
Link 2 http://www.team-integra.net/se...D=644
the one i read from honda tech...says i need a tubing running for the bleeder to a cup of brake fluid. my question is that am i needing the tubing and the cup of brake fluid to look for air bubbles or is there some other reason for it being there? any info would be nice. thanks.
~Eric
Old Mar 14, 2006 | 08:07 AM
purplegsr's Avatar
Default Re: quick question about clutch bleeding (aznsins88)
it keeps air from getting into the line, kinda like when you are bleeding your brakes and you need to submerge the line into a bottle of brake fluid as well.
Old Mar 14, 2006 | 10:56 AM
rgaray's Avatar
To make sure there's no more air bubbles in the system.
Old Mar 14, 2006 | 08:31 PM
stumpyf4's Avatar
Default Re: (rgaray)
^^^ agreed since the clutch pedal will stay on the firewall until you pull it up... so there really isn't any risk of getting air back into the system. You can skip the hose, just watch the stream of fluid. When you see a steady stream you're golden.
Old Mar 14, 2006 | 09:49 PM
aznsins88's Avatar
yea thast what i did...didnt have a hose...but yea...clutch all better now since it shouldnt be doing that...you think the slave cylinder or whatever is bad?
gokblok
Nov 15, 2016 03:13 AM
rpmraper
Nov 10, 2011 04:03 PM
TravisCadello
Oct 29, 2008 07:12 AM
gulfview
Jun 16, 2007 09:44 AM
Luchini
Oct 16, 2005 06:06 PM
