Rough idle on my 97 SE 4cyl
Hey fellas, i havent posted here ina while but i just picked up a 97 SE 2.2 Accord for daily driving. the car only has 64K on it! had a recent tune up with NGK plugs by the previous owner. i have just a bit of an issue with the way the car idles. it idles around 500rpm and when in drive it shakes pretty bad, almost like i have polyurethane mounts in it. i checked out the motor mounts and they seem to be ok (although i couldnt see the rear one). as soon as it goes over 500rpm it smooths out. what can this problem be? I also changed the ATF last night and maybe it was all in my head but i could have sworn it maybe smoothed out a bit.
Today after work i will be replacing the timing belt, water pump, and balance shaft belt, as well as adding the balance shaft seal retainer for routine 9 year old maintnance.
any input will be greatly appreciated!
Is it a rhythmic vibration (dead cylinder) or just a generalized shaking?
Causes could be:
Vacuum leak
Ignition failure to one/more cylinders
low(er) compression
or
out of phase counter balance shaft
I think more towards one of the first three, since you also refer to a consistent low idle (s/b 700rpm), they could be both related by the same cause.
P
Causes could be:
Vacuum leak
low(er) compression
or
P
ok, well i changed the timing belt, balance shaft belt, water pump, and drive belts today. still having that vibration problem. its definately not a dead cylander. its just vibrating. like a bad motor mount. but the mounts checked out OK. i just reset the ECU and maybt that will help my situation. of than that i will check the vaccuum lines on a warmer day.
A 97 Accord is a OBD2 car and should have a check engine light on if it has an engine miss. (Code# PO301,302,303,304, depending on the cylinder) Have a idle relearn done with a Honda HDS and see if it smooths out
* B A N N E D *
it very well could be your IAC, take if off clean the screen with some carb cleaner and clean out the TB as well, i did it on my 2.2CL with 113K and havent had a problem since. it takes like an hour to do minimum. and u accord guys dont have stock strut bars either, so that should save u some time.
themysteriousdj
Jun 25, 2015 10:55 AM
jaygood2go
Apr 8, 2013 08:47 AM
