car starts w/o map sensor in but wont start w/ map in
this is so freakin' strange. my new motor starts without the stock map sensor or 3bar map sensor plugged in and idles good and steady at 900rpms. But when you go to plug in the stock or 3bar map the engine shuts off. I've traced all the ECU pins and they look fine. btw, this is a boosted settup fresh build gsr. anyone got any ideas? checked all fuses and all connections and all plugs. they are good, just dont understand this problem....
get HONDATA thats what i did... But hmm you can get a thing called MISSING LINK.. its goes on your throttle body like a SPACER for the map sensor..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alfee »</TD></TR><TR><TD CLASS="quote">this is so freakin' strange. my new motor starts without the stock map sensor or 3bar map sensor plugged in and idles good and steady at 900rpms. But when you go to plug in the stock or 3bar map the engine shuts off. I've traced all the ECU pins and they look fine. btw, this is a boosted settup fresh build gsr. anyone got any ideas? checked all fuses and all connections and all plugs. they are good, just dont understand this problem....
having this problem also, but at cold start up
</TD></TR></TABLE>having this problem also, but at cold start up
