clutch lines leaking help
hey has anyone ever had issues with there clutch lines leaking??? because when i bleed my clutch the clutch will grab good for bout an hour then it will go back to its sloppiness. its an hdss setup on an ej1. has anyone ever heard of bleeding the clutch with the car on??? i have always done it with the car off. someone mentioned to me to do it with the car on and i didnt want to waste my time if its not going to make a difference.
yeah, I don't think the car on or off would change the outcome at all. After I swapped my B16 into my car with my ACT clutch(xtreme pressure plate) my flex line busted and started leaking. After that...no leaks, just wore out the slave cylinder like 3 or 4 times. Good luck
well i just replaced the master cylinder and slave. and why i asked bout the car on and bleeding it is because we rebuilt a old toyota head this weekend and when put everything back togethor the clutch had lost all pressure well somehow the master cylinder took a **** on us. so we got a new one and bled it for ever and nothing would work. well someone said bleed it with the truck on. so we did and it worked. we bled for hours with the truck off and it wouldnt ever make any pressure. but we bleed it with the truck on for 10 mins and it builds pressure???
B_Swapped93
Dec 14, 2012 04:32 PM
DriveSideWays
Aug 27, 2004 05:06 PM
