Vibrations From Shifter
Old Mar 13, 2006 | 09:21 PM
Onethatwobbles's Avatar
Default Vibrations From Shifter
I have an ek hatch with a d16y7 that has alot of vibration coming through the shifter, its most noticable at idle and fades away some as I go higher in the RPM's. It doesn't matter whether or not I am in gear, it still does the same thing.
Second question is the shifter moves back as I accelerate when in gear and then snaps foward when I release the gas pedal.
Any help would be great. Thanks in advance.
Old Mar 13, 2006 | 09:46 PM
Default Re: Vibrations From Shifter (Onethatwobbles)
Bump for help
Old Mar 13, 2006 | 09:50 PM
sohctodohc's Avatar
yea so ummm... check the three bolts that holds the shifter in and make sure they are tight...and on the second ? that happens
Old Mar 13, 2006 | 09:54 PM
biggnutz123's Avatar
Default Re: Vibrations From Shifter (sohctodohc)
a little vibration is ok just look around the shifter and the linkage most of the time its just somthing easy.
Old Mar 13, 2006 | 10:03 PM
old man neri's Avatar
Your shifter is directly attached to your engine. So when all of a suden you apply torque (hit the gas) the engine moves in the engine bay, your shifter will also. You might have bad motor mounts or a sloppy linkage. Although I really wouldn't worry unless it's a lot of movement.
Old Mar 13, 2006 | 10:07 PM
Default Re: Vibrations From Shifter (old man neri)
Ok thanks guys. This is my first Honda (had VR6's before) so I am still getting used to the changes.
Old Mar 13, 2006 | 10:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Onethatwobbles &raquo;</TD></TR><TR><TD CLASS="quote">Ok thanks guys. This is my first Honda (had VR6's before) so I am still getting used to the changes.</TD></TR></TABLE>
well the differences are that a honda engine will work all the time where as a vr6....no so much. However a VR6 does have something called torque. As a honda owner you will now forget about the existance of any such thing...lol
Cheers.
Old Mar 13, 2006 | 10:36 PM
HAHA!!! No doubt. I find if i pull the seat recliner lever up when accelerating it feels quicker. (Did it on accident once)
Old Mar 15, 2006 | 11:28 AM
Archidictus's Avatar
Unceasing Measure
Sounds like your rear mount is broken to me. Get under there and fix it!
Old Mar 15, 2006 | 11:31 AM
bmoua's Avatar
on my EJ8 it does the same thing....even while its in gear sometimes it vibrates....i means its not annoying but its there....check your bolts...also you can get bushings too...pretty sure that should solve the problem...my friend has the bushings on his and it shifts better and doesn't vibrate...
Old Mar 15, 2006 | 11:54 AM
redlinetuning's Avatar
Tighten up your shift linkage. You probably have worn bushings.
dRoPpEd lS
Mar 9, 2009 09:02 PM
gameknb
Jun 11, 2005 07:32 AM
projectej8
Apr 28, 2005 10:26 PM
pogichinkyguy
Honda S2000
Apr 27, 2004 03:15 PM
Regular Series
Sep 14, 2002 10:41 AM
