00' stock alarm ?
Old Mar 13, 2006 | 06:52 PM
JDM_Andrew's Avatar
Default 00' stock alarm ?
I am thinking of buying a 2000 GS-R and was woundering how good the stock arlarm is because if i get it, i dont have a garage to park it in and would have to park it on the street. is it better or worse than the aftermarket ones? how good is the overall security of the car? and what does the vehicle immobilizer theft-deterrent system do?
Old Mar 13, 2006 | 07:02 PM
teggy182's Avatar
Default Re: 00' stock alarm ? (Drewkraft)
stock alarms are not as good as after market alarm in most cases be cause they do not monitor as much due to fewer sensors
Old Mar 13, 2006 | 07:07 PM
92whtgsr's Avatar
Default Re: 00' stock alarm ? (teggy182)
my dad has the stock one and i got the aftermarket one they both appear to be the same, it's always good to install some of ur own security options like that clutch club thing fuel kill ignition kill etc.. if u have the extra money a aftermaket one is better cause u can get the pager one.
Old Mar 13, 2006 | 07:09 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: 00' stock alarm ? (92whtgsr)
I have a stock alarm, 00 Ls. And i can shake my car and the alarm still wont go off.
But that's ok im getting the compustar and kill switches this weekend
Old Mar 13, 2006 | 08:07 PM
JDM_Andrew's Avatar
Default Re: 00' stock alarm ? (00IntegrAllmotoR)
thanks for all ur replies. i think im gonna do some kill switches and maybe if i have money a 2-way alarm
Old Mar 14, 2006 | 09:40 PM
finest_GSR's Avatar
i have a 2000 gsr.....stock alarm only honk the horn when doors are open...there is no shock sensor or any other features.....a good aftermarket alarm with a clutch club should do it.....no need for kill switch if keeping the original ecu...the 99-01 models are built with the anti-theft immobilzer....this means that without the specific key for the car....the fuel pump won't start....the specific key has a built in chip with codes to match the ecu.....but still...be sure to have the SHOTGUN ready.....!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 14, 2006 | 11:21 PM
Rcp's Avatar
Rcp
Default Re: 00' stock alarm ? (finest_GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by finest_GSR &raquo;</TD></TR><TR><TD CLASS="quote">i have a 2000 gsr.....stock alarm only honk the horn when doors are open...there is no shock sensor or any other features.....a good aftermarket alarm with a clutch club should do it.....no need for kill switch if keeping the original ecu...the 99-01 models are built with the anti-theft immobilzer....this means that without the specific key for the car....the fuel pump won't start....the specific key has a built in chip with codes to match the ecu.....but still...be sure to have the SHOTGUN ready.....!!!!!!!!!!!!!!!!!!!!!!!!!!! </TD></TR></TABLE>
they will bring a ECU from a 98 gsr and just bypass the immobilizer. So yes, you should have a kill switch also.
JDM_Andrew
Audio / Security / Video
Mar 14, 2006 08:23 AM
Hazemm
Jun 9, 2005 11:44 AM
quik89
May 4, 2005 12:34 PM
Asahi
Sep 12, 2002 02:01 PM
