Engine Main and Rod Bearings????????
I just need some clarification on the size bearings i need, stock crank with scat H-Beam rods, I was told i would be best to go with the medium green to be safe, can anyone provide my with some input???
You will not know 100% unless you dial bore the clearances. Or you could plasti-gauge them.
They should use a standard size, but sometimes you may require a diff size. You could always go with the std acl's.
