i need to replace the rear hub but should i get a teg or civic hub?
well my rear wheel bearings are really getting loud and im thinking i should probabyl change them soon. i have a 95 hatch, but i swapped out the rear trailing arms with some old *** integra ones. like 91-93(im not sure exactly tho) integra arms, not the 94-01 integras. i figured that the hubs would be the same considering that everything bolted up easily but when i was looking at new hubs on the autozone website, 95 civic rear disc hubs have a different part number than the integra rear disc hubs. im thinking i should probably get the integra hubs, but i just wanna make sure before i make the purchase.
thanks
-adam
thanks
-adam
i have a 5th gen. civic hatch with del sol rear disc and i bought 3rd gen. integra rear hub. i found out the only differents between the two is if it has the abs ring or not. i have the hub that has the abs ring on it but i don't have abs. as long its for rear disc. hope that helps...
well the teg one specifies if you need the abs or not....like there is two seperate numbers for that too
i really just want to ge the civic one becuase its less money and im cheap, but if it doesnt fit then ill get the teg one!
stripes777
Sep 11, 2008 03:08 PM
