getting code 14 b18a1
Old Mar 13, 2006 | 03:46 PM
rewerbcrx's Avatar
Default getting code 14 b18a1
eacv is that right? actually not to sure if it was code 14
1 long 4 short
any ideas... the car seems to be idling funny... and from what i have read in the book that may be the reason... any ideas for fix:?
Old Mar 13, 2006 | 05:00 PM
RCautoworks's Avatar
Default Re: getting code 14 b18a1 (rewerbcrx)
Code 14 - Electronic Air Control Valve
Lets extra air into the intake manifold, to help control the idle under different loads.
Check the O-rings, for mountng condition.
Clean the inside of the Valve after removing, using any kind of solvent that will remove carbon build up. By spraying it inside the two holes ect...
Place the flat end of a screw driver on the EACV while the engine is running. Place the handle against your ear and listen. Should hear something in there jumping back and fourth at a rapid rate.
EACV Sensor Wires:
1 Blue/Black
1 Yellow/Black
Old Mar 13, 2006 | 05:04 PM
rewerbcrx's Avatar
Default Re: getting code 14 b18a1 (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Code 14 - Electronic Air Control Valve
EACV Sensor Wires:
1 Blue/Black
1 Yellow/Black
pic request to point out on a b18a1 please...
Old Mar 13, 2006 | 05:06 PM
On the back of the intake, or search and you will find it.
90jdmcrxdude
Feb 4, 2006 05:38 PM
b16_madman
Jan 26, 2004 06:19 PM
vteczone
Nov 8, 2003 09:09 PM
untitled
Aug 26, 2003 04:07 PM
BoominD
Nov 25, 2002 10:55 PM
