Clutch Master Cylinder
Old Apr 1, 2002 | 09:10 AM
Mantis's Avatar
Default Clutch Master Cylinder
My clutch master cylinder in my '92 lude has a very small leak in it and I need to replace it but don't want to pay the arm and a leg that the dealership charges. Is this very hard to replace and if not can I get some instructions on how to do it? thanks alot
Old Apr 1, 2002 | 10:34 AM
B19CivicHB's Avatar
Default Re: Clutch Master Cylinder (Mantis)
Its easy... you need to take out the radiator then simply unscrew the fittings and unbolt it from the block. Put the new one in, put fitting back on and bleed the system. Only frustrating part was the radiator. HTH
-Nick-
Old Apr 1, 2002 | 02:04 PM
SCsol's Avatar
Default Re: Clutch Master Cylinder (B18CivicHB)
is it the slave cyilnder or the clutch master that leaking???
Old Apr 1, 2002 | 02:33 PM
Mantis's Avatar
Default Re: Clutch Master Cylinder (lowsol)
I'm pretty sure its the clutch master; after I got my car I took it to the Honda dealership for one of those free 30 minute checkups and they had listed that I needed a new clutch master cylinder because it had a leak if I remember right - but it's been a while. Whats the diff between the two anyway?
siregcivic
Oct 16, 2005 07:55 PM
TurblowR
Mar 28, 2005 06:26 PM
RiCE On IcE 2
Mar 6, 2003 03:47 PM
