SPeed Cable need help ASAP
Old Mar 13, 2006 | 02:07 PM
Civicracer17's Avatar
Default SPeed Cable need help ASAP
on a 93 Teg how do you remove the speed cable that goes in back of the cluster? I have no room to get behind there to discount it
Old Mar 13, 2006 | 02:13 PM
PyeeK's Avatar
Default Re: SPeed Cable need help ASAP (Civicracer17)
after you get all the screws out,you gotta kinda tilt the cluster and reach your hand behind the cluster, feel around and you will find the speedo cable, it's held on by a clip, js push in on the clip and push towards the front of the car....it should come right off...i js did this a few days ago, and i got a 90 da so yea...
Old Mar 13, 2006 | 02:49 PM
Default Re: SPeed Cable need help ASAP (rotate-da)
Thanks it worked I appreciate the fast response
Old Mar 13, 2006 | 03:23 PM
Rikter's Avatar
For future reference. That is the long way and hard way to do it.
When you have all the screws out, disconnect the cable at the transmission side (one clip then it pops out) and then you have all the room to pull the cluster out from your dash and disconnect the cable at the cluster side. It is much easier than trying to get a big hand behind the small space while the cluster is semi-in the dash still.
-Rik
Old Mar 13, 2006 | 03:39 PM
Default Re: (Rikter)
Thanks RIKTER
Old Mar 13, 2006 | 04:49 PM
PyeeK's Avatar
Default Re: (Civicracer17)
disconnectin tha cable...sounds soooooo much easier than tha way i did it...hahah didnt even think about doin it that way...
Dazer 1991
Jul 19, 2012 09:38 AM
95-db6-719
Feb 13, 2010 08:26 AM
evokiller666
Jan 27, 2009 11:47 AM
93egryda
Mar 15, 2006 11:16 AM
cutt
Nov 12, 2004 06:57 PM
