Azenis Rt615 size question
Well today i recieved my Rota slipstreams 16x7 4x100. I was reading that 205-45-16 was the size to get for 16 inch rims. My friend has 205-50-16 and they just dont look right. so to the point i cant find Falken Azenis RT615 in 205-45-16 and also the Azenis st115. do they not make them in these sizes? I did alot or searching and couldnt find the an answer.
they don't make the falken azenis rt615 in 205-45-16 yet. i know their in the process of making them though. but another option you can choose for yours 16's..and if you really want the rt615's i say go 215-45-16. thats the closest size option for the azenis you want.
you should be alright with that drop, but you might get a little rubbing while you angle up or down steep driveways. just go for the 215 and drop a picture on h-t when you got the wheels on. btw my teg is about the same if not a little lower and i'm 205 azenis but i would rock 215 if i had too.
215-45-16 would be ideal. the only reason its not that as common as 205-45-16 is because its kinda an odd ball size. if i had the choice i would go with the 215's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18B-SC »</TD></TR><TR><TD CLASS="quote">215-45-16 would be ideal. the only reason its not that as common as 205-45-16 is because its kinda an odd ball size. if i had the choice i would go with the 215's</TD></TR></TABLE>
this tire size will throw off your guages due to the overall diameter being different thats why 205 are popular not cause of odd ball size
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggy182 »</TD></TR><TR><TD CLASS="quote">
this tire size will throw off your guages due to the overall diameter being different thats why 205 are popular not cause of odd ball size</TD></TR></TABLE>
actually they are both gonna throw the gauges off equally, go check it out if you dont believe me. the 215 is gonna give you a slightly bigger sidewall and a wider footprint
the best tire size would be a perfect match would be a 210-45-16 but obvioulsy thats not a size.
tire calculator http://www.discounttire.com/dtcs/infoTireMath.dos
Thx for the info guys, you all have been a great help i have changed my mind and i have decided to go with some Hankook Rs2 s 205-45-16 i read some good things about them
