pruchasing used ITR rear sway, what else needed....
Old Apr 1, 2002 | 08:41 AM
maxxdout's Avatar
Default pruchasing used ITR rear sway, what else needed....
other then the BSQ or Beeks kit, what other parts associated with the rear sway should be removed from the car inorder to reinstall onto my LS?
--assorted bolts??
--any bushings???
--retainsers???
thanks
Old Apr 1, 2002 | 09:18 AM
BROOD's Avatar
Default Re: pruchasing used ITR rear sway, what else needed.... (maxxdout)
Here is what I 'm using for an ITR bar with the Beaks kit:
~ITR sway bar
~ITR endlink bushings and sleeves
~ITR sway bar bushings
~ITR bushing "D" brackets (holds bushings to beaks mounts)
~all of the endlink parts and hardware
~rear lower control arms with provisions for the endlinks
rear lca's can be sourced from 'teg GSR, DelSol Vtec, or 5th gen Civic EX sedan
Hope this helps, I might have forgotten something. If so, someone else will catch and fill in the info for you.
PS. if you use the ITR rear lower control arms, plan on changing your rear struts to ITR type struts. The GSR, DelSol Vtec, and EX sedan lca's will use your stock LS 'teg struts.
[Modified by SLPR, 10:21 AM 4/1/2002]
Old Apr 1, 2002 | 10:09 AM
96IntegraLS4DR's Avatar
Here's part number of every nuts and bolts from BSQ site.
1.) 52300-ST7-Z01 type-R rear swaybar
>> >2.) 52315-ST7-Z01 swaybar bushing
>> >3.) 52308-SS0-000 bushing bracket
>> >4.) 52316-ST7-Z00 endlink bushing
>> >5.) 52312-ST7-Z00 endlink bushing collar
>> >6.) 90175-ST7-Z00 bolt (8x35) >> >7.) 94050-08080 flange nut (8mm)
Old Apr 1, 2002 | 10:22 AM
5-SpeedFreak's Avatar
New User
Default Re: pruchasing used ITR rear sway, what else needed.... (96IntegraLS4DR)
BSQ
Aracheon
May 3, 2005 10:21 PM
MaaseyRacer
19
Aug 14, 2004 08:33 AM
92hybridhhatch
Aug 14, 2003 12:39 AM
SilverGS
Nov 14, 2001 10:25 AM
