Honda S2000 Honda S2000
how do i reset my ecu??? Do I have to take it to the dealer?? Thanks for your help!!
Old Mar 13, 2006 | 12:30 PM
DrewkCarrigan's Avatar
Default how do i reset my ecu??? Do I have to take it to the dealer?? Thanks for your help!!
Old Mar 13, 2006 | 12:42 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: how do i reset my ecu??? Do I have to take it to the dealer?? Thanks for your help!! (DrewkCarri
Disconnect battery or unplug the ECU for 30 seconds. Make sure you re-do "Idle Learn".
Why do you need to reset?
Old Mar 13, 2006 | 03:19 PM
LBBP R's Avatar
^^it's probably easiest way.
1)disconnect battery
2)pull fuse
3)disconnect harness to ecu
Old Mar 13, 2006 | 03:32 PM
Ross 2.0's Avatar
In a Junkyard near you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LBBP R &raquo;</TD></TR><TR><TD CLASS="quote">^^it's probably easiest way.
2)pull fuse
3)disconnect harness to ecu</TD></TR></TABLE>
Umm a bit overkill.
Honda's official way is to remove both battery cables and touch them together for a few seconds.
If your trying to clear a check engine light that isn't going to do it.
Old Mar 13, 2006 | 04:51 PM
Nishant's Avatar
just disconnecting the battery will clear the check engine light, it will also reset the ecu. disconnect the battery and wait a min or so to reconnect
hondaracer4vtec
Honda Civic (2006 - 2015)
21
Sep 12, 2008 08:12 AM
Boring
10
Dec 3, 2004 11:31 AM
bigslimdog
Mar 30, 2004 03:07 PM
SleepnCiViC
Dec 5, 2003 02:56 PM
Btothe3rdDegree
Aug 30, 2003 07:29 AM
